NEW MEMBER: Im wondering what you think the best CAI for a 7th Gen. Civic ?
Old Aug 11, 2002
ruffles3's Avatar
ruffles3 is an unknown quantity at this point
Im thinking of getting AEM Cold Air Intake with the air bypass valve but not sure if theres something better out there. Any product reviews or info. on this subject is much apprecaited. [IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Aug 11, 2002
NAcoma's Avatar
NAcoma is an unknown quantity at this point
Injen
depending on where you live you probably wont even need the bypass valve..but if youre set on having it i think it works on Injen
Old Aug 11, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Injen is true cold air... it takes it in from the fenderwell rather than behind the radiator. Unless you live somewhere where floods are possible, you don't need the bypass. Search around on here... this has been beaten to death already.
Old Aug 11, 2002
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
SEARCH, SEARCH, SEARCH AND SEARCH AGAIN!!!!!!!!!!!!!!!! If not the next time you will be put on a pedistal and have rocks thrown at you by man eating midgets!!!
Old Aug 11, 2002
mullinad's Avatar
mullinad is on a distinguished road
I have the AEM and I like it alot....
Old Aug 11, 2002
RookieTuner's Avatar
RookieTuner is an unknown quantity at this point
the injen short ram has actually been putting out better numbers than the AEM cold air -when dynoed-. i have the injen short ram and i love it. i bought the heat shield and thermal wrap and it performs great. the AEM and injen cold air intakes are very long and have many twists making air flow harder. they also pose the possibility of sucking water and totaling yourt engine. the short ram from injen is very short- thus the name short ram- and it has one bend. only problem is that it takes in hot air. but its all about what you perfer. i like my injen SRI on my 2k2 civic.
Old Aug 11, 2002
by the way the AEM bypsss valve is horrible.
Old Aug 11, 2002
Toad's Avatar
Toad is an unknown quantity at this point
whys the bypass so bad?
Old Aug 11, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
actually rookie the injen sri gives out more hp on diffrent level of the powerband and the aem cai does the same. However it was proven that the injen cai gives out more hp over the same powerband as the aem cai. Its not much more but with out cars every lil bit helps. Also all the major avalible brands out for our car right now are: K&n, Aem, Injen, And iceman. Theres alot more out but i havent herd anything about em. I personally have the injen and i love it. Its much louder than the aem, however the aem is deeper. Hope i helped.
Old Aug 11, 2002
ruffles3's Avatar
Thanks all for the help i'll take a look at the injen and search around.
Old Aug 12, 2002
JDMCIVIC's Avatar
JDM WHORE!!!
JDMCIVIC will become famous soon enough
Injen all the way.
Old Aug 12, 2002
JRS1's Avatar
JRS1 is an unknown quantity at this point
i have AEM CAI and i like it a lot, pretty much the same as injen. AEM is easier to install. Don't get bypass valve unless u live in a flood area, bypass valve is really not needed it only works when filter is submerged under water. Go with a CAI get either Injen or AEM
Old Aug 12, 2002
midvis's Avatar
Vic On Dubs
midvis is an unknown quantity at this point
This is my theory and correct me if I am wrong please, but isnt all the piping the same? I mean a CAI is a CAI riiight. Isn't the differance just in the actual Filter it-self? It just looks to me like all the piping has to be bent the same way for it to fit into our engine bays so there cant be a big differance there. And all the piping is the same diameter as far as I know. So the way I see it you could go on ebay and get a cold air for $80( filter included) and if you wanted maximum performance then get a nice filter for around $30 and have the same intake as the Injen or AEM for alot less.
So am I right or am I wrong?
MIDVIS
Old Aug 12, 2002
StraightEdgeCivic's Avatar
StraightEdgeCivic is an unknown quantity at this point
well..there all pretty similar..but the differance is also where the filter is located...injens CAI's filter is located lower then the AEM...thus sucking up cooler air.
Old Aug 12, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
I'd have to recomend the AEM CAI myself, since I've had it for awhile now and no problems at all (no bypass valve for me). It is much better then the Injen SRI I had before.
Old Aug 12, 2002
badcivic2002's Avatar
badcivic2002 is an unknown quantity at this point
what size piping does the Injen use?
Old Aug 12, 2002
y2k2ciVic's Avatar
y2k2ciVic is an unknown quantity at this point
WOOOOO HOOOO my injen will be here thursday!!!
Old Aug 12, 2002
L23Tan's Avatar
L23Tan is an unknown quantity at this point
I have an AUTOMATIC... does AEM make CAI's for auto? Some ppl were saying they only make it for 5-speeds. Is this true?
If this is true... what's my NEXT BEST choice for a CAI?! I am not looking to go for a SRI. If you guys are gonna say the Injen Race Division CAI is what I should go for... what kind of filter does it come with? I want a K&N.
Old Aug 12, 2002
hondadude's Avatar
hondadude is an unknown quantity at this point
I am about to order one. I'm having a tough time deciding too. I think the AEM looks better, but I think the majority think the Injen performs slightly better and sounds better. So I don't know what I'm going with yet.
Old Aug 12, 2002
NAcoma's Avatar
injens cai will fit 5speed.. and yes it is a lil better
injen
Old Aug 12, 2002
bong's Avatar
bong is an unknown quantity at this point
Nah man. Definitely get the Injen C.A.I. I have it and it works awesome. No bypass valve needed...better cold air since it sits in fenderwell instead of behind radiator and/or under the hottttttttttttttt engine. I live in FL where it already rains and it stays pretty dry down there...remember no being kewl and taking them puddles
Old Apr 17, 2003
bong's Avatar
I live in Florida too. Behind the wheel protects the water from coming in. I have a modified whole in my bumper to allow cooler air in and it has a flap for those rainy days to keep water out. Other than that, I've used it @ top speed on highways on rainy days and it manages to stay dry. Stay away from those PUDDLES!
Old Apr 17, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Locked... too many threads about this.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
AB
17
Nov 8, 2001 09:54 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
burtn6
Nov 4, 2001 09:20 PM
Wanger
Oct 19, 2001 10:37 PM
