speed problem
speed problem
i have a 2004 civic ex coupe sohc no vtec and i cant seem to do over 80 i know how to drive but i cant seem to get my car faster than 80 also at 60 in 5th it revs at about 3500rpm can anyone help me if theres a problem? im pretty sure it was a company car when it was first bought so there may be a speed limiter on it but i doubt it.
Re: speed problem
is the engine light on? ive made it to 100mph once in my 2002 civic ex auto and couldve kept going higher. its possible but takes a long time.
Re: speed problem
might just need a good tuneup. new plugs (ngk or denso), clean out intake parts, check fuel pressure, new air filter, auto-rx.com oil treatment system if the engine was neglected (probably), make sure brakes arent dragging, tires at around 35psi, etc. here is a good start.
https://www.civicforums.com/forums/1...e-up-mods.html
Re: speed problem
moved to the correct sub forum..
by the way, what, pray tell, have you done to make it faster?
conspiracy90
Jun 7, 2023 01:01 PM
jakeconnor
May 5, 2015 07:30 AM
dragonsblood
Apr 27, 2015 12:28 PM
dooner24
Apr 14, 2015 07:51 PM
