Intake question
Old Oct 6, 2004
Satanic-Hamster's Avatar
Satanic-Hamster is an unknown quantity at this point
Intake question
this was probably answered before, but I can't find the post!
So, I know for a fact, that injen Race Division for automatics are bitch to install.. but is cutting required?
Is there a DIY for it?
Old Oct 6, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
The intake comes with instructions.
Old Oct 6, 2004
VietScouty's Avatar
VietScouty is an unknown quantity at this point
I believe so, I haven't installed tha other half of tha intake...cuz of the fear of rainy season here in So Cali.
Old Oct 6, 2004
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
are you talking about the cold-air intake?...'cause i have the short-ram, and the only problem was that the air-flow sensor didn't quite fit where it was supposed to on the new intake, and i had to trim up a grommet kinda thing and stick around it to make it snug so it wouldn't fall out...but other than that it was all super easy...i had never done an intake before, but it came with instructions, and i had it on in less than an hour...hope this helps...good luck!
Old Oct 6, 2004
binky's Avatar
binky is an unknown quantity at this point
hey vietscouty, how did you leave just the top half, i tried that and my filter won't fit cause i don't have enough room. i got mine installed without any cutting, install was a breeze. just follow the directions
Old Oct 6, 2004
VietScouty's Avatar
Binky: I had a different air filter which is a little smaller than tha one Injen had given. How in the world did u manage to do it without cutting? Last time I heard is that you don't even have to remove the front bumper...
Old Oct 6, 2004
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
all u need to do is cut that splash guard or whatever its called, the black plastic thing, which u could probably do with a knife.... Its not hard, just as easy as a short ram, except u cut the plastic thing out.
Old Oct 6, 2004
ACURAwerx's Avatar
im talking about the black plastic thing there the filter will go thru, under ur passenger headlight i believe, tkae off ur bumper and ull see it and be able to cut a little part of it off so the bottom part of the intake can go thru
Old Oct 6, 2004
VietScouty's Avatar
Much thanks Acurawerx
Old Oct 7, 2004
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
i had problems after i installed it. if your gonna do this be careful about the metal piece, the intake pipe will probably rub on it
Old Oct 7, 2004
steak84ss's Avatar
steak84ss will become famous soon enoughsteak84ss will become famous soon enough
I installed the short ram on my automatic. That was a joke. I had to bend the braket a little with pliers but thats all. I'm assuming that the long/race CAI is hard to install?
Old Oct 7, 2004
ACURAwerx's Avatar
the cai is the same as the short ram except the filter will locate further down on the engine bay. once the top piece is connected (Short ram). all u do is connec thte bottom piece of the intake, which doesn't connect to anything but the top piece (which is connect to the brackets and stuff)... so besides the cutting to allow the filter to go into the desired location, which all it is is cutting a small square or wahtever, short ram and cold air are the same degree of difficulty to install
Old Oct 7, 2004
civicvtec1ps's Avatar
Search and Learn
It's easy to install.
Bumper is easy to remove as well.
Old Oct 7, 2004
Honda2k4's Avatar
anyone else have an 04 with injen cai, im wondering if thats the problem
Old Oct 7, 2004
noVICe's Avatar
noVICe is an unknown quantity at this point
on 04 civics with auto you can only use short ram because there isnt enough space. the CAI only fits 04s with manual tranny. hope that helps you out. i have short ram aem and it fits perfectly with very little room to work around.
Old Oct 9, 2004
vtecman04's Avatar
vtecman04 is an unknown quantity at this point
what about the v2's is there enough room on auto's for those.
Old Oct 9, 2004
V2 is just a short ram intake for the new civics. And yes, the Injen cai needs some cutting of things to fit or else it will scrape and ruin the intake.
carid
Nov 7, 2015 01:46 AM
Farticle69
Aug 6, 2015 08:02 PM
spyder13
Jul 31, 2015 06:31 PM
NoobyKid
Jul 13, 2015 07:53 AM
Ccoop87
Jul 9, 2015 03:26 PM
