View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
#121
Hypothetical D16 swap?
I understand that this is NOT a practical swap for many reasons, but COULD I hypothetically mount a D16 motor on my D17 trans, and run the D16 with my D17 ECU? I see no reason why it wouldn’t work since the D17 ecu will provide spark and fuel if I mod the harness to plug into D16 sensors and fuel injectors and use the COP ignition system, although I am sure it would have issues and not run properly if it did start. I understand that there would be issues like the exhaust not connecting, coolant hoses, etc. But it would theoretically start, right? I have no plans of actually doing this, but technically I see no reason why this wouldn’t work. Do you?
#124
Should I get a VTEC ECU?
I have a 2005 Civic LX that I put a D17A2 VTEC motor in. It has been running on the stock ECU for about a year just fine, but I am wondering if there would be a performance or gas mileage benefit if I get the proper ECU. I wired a switch for VTEC since the stock ECU won’t automatically activate it, so I presume that the only benefit to getting a VTEC ECU is automatic VTEC, I wouldn’t think that performance would improve. But I heard that the VTEC ECU has more advanced ignition timing and different fuel tables, so it performs better. Which is true? Also, if I get a JDM ECU, which supposedly makes more power and improves gas mileage, will it work with a USDM immobilizer and key, or would I have problems? Thank you in advance.
#125
What do I need to know about installing a JDM ECU?
I have a 2005 Civic that I would like to install a JDM D17A ECU in. What do I need to be aware of? I have some questions:
1. Will the ECU plug and play?
2. Will US scan tools connect to JDM ECUs?
3. Do JDM ECUs have immobilizers? If so, can Honda flash it?
4. Will the car gain power or get better gas mileage?
Thanks for the help in advance.
#126
Received 1,440 Likes
Rep Power: 338 Re: Hypothetical D16 swap?
Depending on state emission department, an engine older than the chassis could cause you problems.
check that first
check that first
#127
Rep Power: 338 Re: Should I get a VTEC ECU?
tons of threads asking the same around.
search before asking
VAFC, etc.
VAFC, etc.
#131
Read reply #26 in this thread: https://www.hondacivicforum.com/foru...2-35930/page3/
#132
#133
Re: What to expect with Stage 1 camshaft?
1. What procedure do I follow after I lube and install the camshaft to break it in?
2. I am due for an oil change.
3. Will the performance benefits of the camshaft be immediate, or will the ECU need to adjust?
I bet there is zero break in on the cam simply because the engine uses rollers on the cam followers.
Install it, adjust valve lash TO THE SPECS IN THE INSTRUCTIONS, then drive it like you stole it.
#134
Re: What do I need to know about installing a JDM ECU?
WHY?
Doesn't your car have a working ECM already?
#135
Consult the instructions that come with the new cam.
DO IT NOW
It will be immediate.
DO IT NOW
#136
The ECU is acting strangely. It is setting random codes, along with flashing the engine light with no misfire. The car is running fine, but I just want to change it before it completely fails and strands me. Since a JDM ECU is the same price as a USDM, I was just asking if I should go JDM.
#137
My guess would be similar MPG as the ECU will set itself to the octane level of US fuel.
JDM ecus are immobilizer programmed so you would still need to pay for a reflash
Only US part of a scan tool is the use of English..
Always best to match up exact part numbers when it comes to ECUs, if the JDM one is a exact part number match then yes it will be plug in simple .
#138
#141
Received 1,144 Likes
Rep Power: 485 Re: What to expect with Stage 1 camshaft?
nope. do it cold. I contacted crower about it and they said cold despite saying hot on their site.
.006" intake and .008" exhaust for the stage 1 in case you need it
#143
#144
Re: any specific instructions for when installing Stage 1 camshaft?
I've worked with other brand cars that specified to adjust valves on a hot engine, but Hondas valves are adjusted when the engine is COLD. Cold being room temperature....At least Below 100*F
IDK why the Crower website would say to do it hot, unless someone just made a blanket statement without knowing the differences or didn't check out the actual instructions for these particular cars. Web designers and IT specialists are rarely "car people" so little details that matter a whole lot to us probably make very little sense or difference to them.
#145
Can I make my own K-Pro?
I understand that K-Pro is a board that goes into the ECU, but what would the process be for getting it installed? Would I send my ECU to Hondata and the price of K-Pro includes installation, or would I buy the K-Pro and plug it into the ECU myself? Considering Hondata charges $675 for a cam gear that probably costs them $2 to make, $400 for D17 K-Pro to be able to tune my engine just seems too good to be true. “Only” $400 probably wouldn’t be enough of a ripoff for a tiny board for my ECU that probably was made in China and cost Hondata $3! So how does K-Pro work? Thanks.
Last edited by sdaidoji; 11-29-2017 at 04:22 PM. Reason: "How does it work" is really not what OP wanted to ask - changed title
#146
Prelude Owner
Re: How does K-Pro work?
$400 is if you send them an ECU. They add their unicorn blood magic bits and send the ecu back, you instal. Your paying for labor, software, Hondata guarantee and knowledge. I’m sure the circuit board they add does not cost much but someone engineered and designed the system, that costs money.
This is all explained on the website.
#147
Best A/F ratio for power?
Completely disregarding emissions, engine longevity, and fuel consumption, what is the best A/F ratio for power? I would think that theoretically, EXACTLY enough fuel to burn ALL the oxygen, but NO extra fuel(stoich)would make the most power. But since there is really no way to measure and regulate air and fuel flow that precisely, I would think that enough fuel to burn all the oxygen and have a little fuel left over after the combustion event, so slightly rich, like an A/F ratio of 14.4-14.5:1 would make the most power. But according to Engineering Explained, 12.5:1 is the ideal ratio for power. I am not sure why injecting so much more fuel than you can burn would make more power, but there must be a reason he said it. What do you think?
#149
Rep Power: 338 Re: How does K-Pro work?
what cost is not the hardware, it's the software and what's within it and all the blood and flesh they left behind to test and make it work..
