HX/EX parts
HX/EX parts
Okay so I need to know if my D17A2 is the same as the D17A6. If it is i am golden. If its not then I am gonna scrap it and get something else. The D17A2 is what I have. It is in a civic HX 2001. I want to know if the mods for the D17A6 are the same i.e manafold, intake, pistons, cranks. Im looking for some good news here fellas. thanks
Re: HX/EX parts
I'm almost positive there the same. You might have to swap a sensor or two. I used a non vtec motor remake my ex motor. Just rebuilt the head and put the vtec head on the non vtec motor and it works better than stock. Have no speed governor anymore. Haha
Received 1,437 Likes
Rep Power: 338 Re: HX/EX parts
D17a2 VTEC
Found in:
2001-2005 Honda Civic EX (US only)
2001-2005 Honda Civic LX (Europe)
2001-2005 Honda Civic Si (Canada only)
2001-2005 Acura 1.7 EL (Canada only)
2000-2007 Honda Stream 1.7 (Japan)
Displacement : 1,668 cc (101.8 cu in)
Bore and Stroke : 74.98 x 94.4 mm (2.952 x 3.72 in)
Rod Length : 137 mm
Rod/Stroke : 1.48
Compression : 9.9:1
Power : 127 hp (94.7 kW, 132 ps) @ 6300 rpm
Torque : 114 ft.lbf (114 ft.lbf USDM[3]) (15.8 kg/m, 155 Nm) @ 4800 rpm
RPM redline: 6800 rpm
Rev-limiter : 7200 rpm
Valvetrain : SOHC VTEC (4 valves per cylinder)
VTEC Switchover : 4500 rpm
Fuel Control : OBD-2 MPFI
D17A6
VTEC-E
Found in:
2001-2005 Honda Civic HX
Bore and Stroke : 75 x 94.4 mm (3.0 x 3.72 in)
Compression : 9.9:1
Power : 117 hp (93.2 kW, 127 ps) @ 6100 rpm[4]
Torque : 111 ft.lbf (15.3 kg/m, 150 Nm) @ 4500 rpm
Valvetrain : SOHC VTEC-E Lean Burn (4 valves per cylinder)
VTEC Switchover : 2300
Found in:
Rod Length : 137 mm
Rod/Stroke : 1.48
Compression : 9.9:1
D17A6
VTEC-E
Found in:
Compression : 9.9:1
mohawkboom
67
08-25-2015 12:28 AM
Tim1959
06-03-2015 08:15 PM
juror
05-26-2015 06:35 PM
