Mnaifold studs
Rep Power: 0 Mnaifold studs
EDIT: Manifold Studs*
Ive been visiting this site for some time now and finally decided to make an account on it, ive tried looking everywhere, all over google and many other sites but cant get a straight answer anywhere.
I need a new manifold so im just gunna buy a full system and on my exhaust now the bolts are oxidized in place. The studs along with the manifold have gone discolored and theres no way the studs will go back on when i get them out with the oxy heat.
So im going to need to order new ones, i like to avoid dealerships because thats just way to expensive for me, i need to know the size for the studs. Its a d17 03 civic, putting the manifold on the block. Everything else is in the shop manual at work except those. Ive seriously tried everywhere.
Ive been told M8, but that doesnt answer the length or anything else. Any help would be great, and this is my first post on the site, but in no way my first visit. Thanks in advance.
Re: Mnaifold studs
The studs will come out with a little PB blaster and letting it sit for about 10 minutes....Take the studs in to fasten-all and they can match up what you need...just make sure you get the high heat rated ones...
Re: Mnaifold studs
I'll take a wildass guess and say yours are 8x1.25, x38mm long.
Look your car up here, the hardware sizes are quite often listed. www.hondaautomotiveparts.com/
Or pull one out and see how long it is.
I usually have no problems with the studs themselves, and the nuts come right off. There's plenty of heat on them every time the engine runs. They don't normally get bad.
So what if they LOOK bad? Have you TRIED to take it apart?
They can come apart just fine. Use a 6-point socket on them.
The heatshield bolts will go to hell though. They round off or snap off. Not critical, so no biggie.
Rep Power: 0 Re: Mnaifold studs
PierrePierre
08-12-2015 02:42 PM
sf3r8z
08-11-2015 02:32 PM
