Finally Installed w/pics!: Weapon R Secret Weapon Intake.
#93
A descendant of 2k1civic.com
1 Post
Rep Power: 335 Re: Finally Installed w/pics!: Weapon R Secret Weapon Intake.
I actually think it will. I'm not 100% sure because I don't have a strut bar, but check with gearbox, if I remember correctly he has a strut bar with this intake. *edit, gear beat me to it.....**
It could be a situation where some strut bars will work and others will not. Like the DC sports may not work because it's a straight peice, but a Neuspeed might be ok because it bends a bit.
This intake has several peices that fit together so you can actually turn it different directions when installing for somewhat of a custom fit.
#94
Rep Power: 787 Re: Finally Installed w/pics!: Weapon R Secret Weapon Intake.
pics of the pvc hose? i still have the original which is a bit too small and i had to stretch it over the holes and ziptie the middle to keep from bending. it works but id rather have something nicer and black if possible instead of grey.
#96
neuspeed is so much better than dc tho...just swap it out lol
#98
Rep Power: 205 Re: Finally Installed w/pics!: Weapon R Secret Weapon Intake.
the aemv2 works fine with the dc bar, along with the aem cold air, as you can read in the above link
#100
Rep Power: 287 Re: Finally Installed w/pics!: Weapon R Secret Weapon Intake.
this intake looks very similar to the injen one, so your DC strut bar should fit fine. which one do you have? the titanium one ? or the older model one that bends to the front and is a 3 piece strut bar.
either way, it will fit fine.
or you can just buy an INJEN short ram intake and 100% sure it will fit. either way it will fit. don't worry too much about it.
also, yes the neuspeed one is a LOT better than DC.
#101
I was actually considering this weapon r secret weapon intake for my 06 civic. Do you guys have an older model civic? If so, to you think I will still have the problems that ya'll had with the weapon r? For example, the shortness of the MAF sensor, the hoses that don't fit or whatever, etc. I don't know a WHOLE LOT about engines but I'm looking into getting a short ram intake so that I can free up some engine bay area so that I can put a bigger battery under the hood. Thanks for your help.
Touge
Ottawa
06-23-2015 02:48 AM
Touge
06-23-2015 02:04 AM
Touge
Ottawa
06-05-2015 11:15 PM
