Least obnoxious intake? (Video of my AEM CAI inside)
Rep Power: 0 Least obnoxious intake? (Video of my AEM CAI inside)
Good lord people, after searching and reading 30min worth of posts I've got a migraine.
Bah.. anyway, my 2001 EX 5 speed Coupe daily driver's AEM CAI is starting to get really annoying. Anything above 2500 rpm and it just gets obnoxious. I usually shift high up in the band, I'd say 4-5k. Drive it like I stole it cause I have to to get it to go anywhere.
Don't tell me to go back to stock, I don't want to. Even if I did, I doubt I can find all the bolts and brackets of the stock system.
Anyway, who makes the quietest intake? PLEASE only people with first hand experience respond!!! Those that swapped from CAI to SRI or vice versa or those that have audio or video of your intake revving to redline would be great.
Also, I could car less about performance or what the intake looks like.
Here's a short 1.8meg vid of me revving to about ~2500 I believe and you can tell the intake is already getting loud.
http://www.members.***.net/mkm1009/a...ke%20movie.MPG
Rep Power: 0 I have the same intake and its not that loud..... not sure why yours would be louder, maybe you need to clean the filter... anyways... now that i have my exhaust I can't even hear the intake except when I turn my car off... I kinda miss hearing the sound when I just had the intake....
7thgen Man-gina
Rep Power: 0 isnt aem a two piece system? so couldnt you take the cai extension off and just make it into a short ram system? i have the aem sri and its quiet, just makes a bit of noise when you need it to
Jap-Euro Fusion
Rep Power: 399 Quietest intake is stock...
Deal with the noise or go back. Thats really all you can do.
The Injen RD is gonna be a little quieter since the filter is down in the bumper and theres lots of plastic to shield the noise. It resonates about 6000 RPM so it'll get louder there, but it really doesn't bother me below that. Just get used to it.
Here's an all out run... it was really for my exhaust, but its so quiet the intake takes over a little towards the end.
Here
Here
Rep Power: 0 Sometimes I wish my intake sounded a bit louder.
I have a AEM CAI with bypass valve. I believe mine is as quiet as it is due to the bypass valve. I have yet to hear what its like with the bypass removed, but I suggest giving that a try.
Rep Power: 0 Originally posted by 01WingsWestCivic
I was thinking of maybe doing that, thanks for suggesting. It looks like another member on the board did exactly that... turn the AEM CAI into a SRI using just the upper tube.
Here's the thread:
http://www.7thgencivic.com/forums/sh...cai+first+half
Most important for me was this part:
2) The car is a LOT quieter... almost as quiet as stock. In low RPMs, it's so quiet all I picked up was wind & road noise. In high RPMs, I can't even tell when the VTEC kicks in as I actually could before, even with a lil throttle manipulation. Right here, it's is slightly louder than stock. I found this as a pro and a con. It's a pro because the intake doesn't attract so much attention even in a downshift. To say the least, driving long distances is a lot more pleasant. I'm also quite sure that the car even idles quieter.
Rep Power: 0 Originally posted by BoSS
whats wrong with it? Sounds like my AEM CAI
Ricer Loud = attention I don't want.
If I want to drive around w/ an obnoxious intake/exhaust system.... I'll take the Firehawk out for a spin
Rep Power: 350 but to answer your question...check out the weapon R system or the volant CAI system both should be the quiestest...Also that racer design intake sysystem is quiet i hear
Rep Power: 350 mines not all that loud over my exhaust i can hear it hiss after i turn the car off but if you want quiet maybe something with an airbox around it. There are two out there cant remember the names of them no
Premium Boosted Member
Rep Power: 302 I have the Tsudo CAI - definately close to no sound. The engine gets a little louder, but there's no intake throaty scream when you punch it. Still feels good though. You can get it for less than $100 on nopi.com. That's seriously the quietest intake i've heard on anyones car, never mind just civics.
Rep Power: 0 Originally posted by R3DL1N3
whyd you get an intake if you dont want the sound? thats retarded. just be sure not to get an aftermarket exhaust.
Originally posted by 2k3HonCivicEX
fo real, intakes not that loud, get used to it, or dont. but dont cry about the sound when you knew what it was like going into it.
Bah, back on topic. I took the lower pipe off and couldn't be happier. Below 4k you can barely hear the intake like before. It dosen't whistle or growl like the CAI, which is a plus for me. Now when you let off the gas it dosen't do the faux bov sound either which is another plus for me.
Under easy to mild acceleration, the car sounds nearly stock. If I WOT and wrap it up redline I can still make it sound ricey and obnoxious though. Throttle response does seem to be quicker, though the car isn't as 'rev happy' now. Running it past 4k takes determination. Which isn't a bad thing in my book, hopefully I'll pick up a mile or two in MPG now that I won't be wrapping it redline all the time now.
Edit- Oh and yeah, thanks to those that posted constructive comments to this thread.
Ricerus Maximus
Rep Power: 307 If you're worried about go and not show, put a header wrap on it, tight. This will not only help keep some hot air out and insulate the pipe, but the main thing you are hearing that is annoying is the aluminum piping resonating with the vibrations of air passing through it at high speed. By wrapping it you will dampen the amount of vibrations thus creating a quieter intake.
Rep Power: 0 i wish my aem cai is loud.... mines not even loud and i can't even hear it.... first when i had my muffler and the intake installed... i thought my intake was loud... but i tried putting on the silencer on my muffler.. and it was just my muffler sounding loud.. not the intake...... my friend who has a aem cai in his 98 honda accord.... that intake is hella loud.... wish mine was like that....
Rep Power: 0 Originally posted by VTECTypeR
jkim make your aem CAI into a SRI it should be louder
Escaped Convict
Rep Power: 343 lol.
another great civic owner. *rollseye*
btw, since you seem to be so into power in a civic (rollseye again), you're losing power when you do that (swapping it into an sri)
you're better off stock + drop in filter than that setup... at least you dont lose low end torque.. and you get more mpg.
the volant system might be near stock, since filter is incased within a box.
I make fun of my car sometimes, cuz it is darn slow. and you do have to rev the hell out of it.
but I dont understand why some peopel drop 15-17k into a car and get surprised when it isn't fast or its too slow.
