Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
no idea if this is a good set up or not
Old Dec 13, 2010
  #151
Stock 99's Avatar
Re: no idea if this is a good set up or not
Hi there!
sorry to bust in on the conversation but....
There's a guy in Edmonton that deals with console gaming stuff he might know where to get the hardware. foundmy.com
I've built my own PIC chip programer for like $30 and burning chips is very simple. I dunno about the actual programming of it though.
You can get blank chips from digikey.com
Here's the info on chrome
File Type: pdf
Old Dec 13, 2010
  #152
MindBomber's Avatar
Live for the Twisties
Never worry about busting in on conversations on this forum, we're all friends here and any advice you have to give is always more than welcome and encouraged!
You never know who might find information helpful, once exams are over I might look into Chrome for my E30 since its cheap lol.
Originally Posted by Stock 99
Hi there!
Old Dec 13, 2010
  #153
civicnewb's Avatar
civicnewb is an unknown quantity at this point
i would guess a turbo shop with older veteran tuners
Old Dec 14, 2010
  #154
civicnewb's Avatar
so this is the third time i have had the turbo out... i can do it under 5 mins... could probably do it blindfolded... don't know if that a good thing or not haha, atleast i know exactly what to do to get it out now.... I MAY HAVE FOUND THE PROBLEM!!! the gasket material i was using to create my own gaskets was a thick cardboard type material... i think that when my car got hot enough it would burn it leaving a gap which means the bolts would be loose and they would vibrate and back off... i changed my material to some stuff that won't burn we will try this
Old Dec 14, 2010
  #155
civicnewb's Avatar
i think the attachment that stock 99 just gave needs to be stickied somewhere... VERY useful
Old Dec 15, 2010
  #156
Mad Dog Tannen's Avatar
Use a locknut!
And metal type gasget material
Old Dec 15, 2010
  #157
civicnewb's Avatar
Originally Posted by Mad Dog Tannen
Use a locknut!
man i tried... i can't get lock nuts in there.... see this turbo is built with threaded holes... but with this application there is no way you could have had bolts going threw the turbo AND the manifold... so the holes were drilled out and a piece was fabricated with studs... since the turbo was not built this was its extremely hard to even get a nut tight because its so close to the casting of the turbo... and for gasket im using what i have... i emailed mitsubichi and haven't had a response yet.
Old Dec 15, 2010
  #158
A locking nut then!
Old Dec 15, 2010
  #159
MindBomber's Avatar
When you make your own gaskets the best material to use its 1/8 inch copper.
Old Dec 15, 2010
  #160
civicnewb's Avatar
as i said can't get a locking nut in there... there too big... and i ordered the right gaskets
Old Dec 15, 2010
  #161
^ I don't think we are talking about the same things.
A locking nut= a nut that has a extra top part that adds pressure to the treads to prevent it from loosening
A lock nut= A second nut that locks the first one on the bolt
Old Dec 15, 2010
  #162
you talking like a jam nut
or a lock washer?
because I'm kinda confused as to what you're getting at, too.. Just kinda..
Old Dec 15, 2010
  #163
MindBomber's Avatar
+1 dude, I'm pretty smart, but I'm no nut expert.
Old Dec 16, 2010
  #164
civicnewb's Avatar
yeah i got it now... he talking about a jam nut... as for a lock washer there is NO ROOM AT ALL! and for another nut to go on...? NO ROOM there isn't enought threads on the stud left... if there were the adaptor wouldn't fit...
Old Dec 16, 2010
  #165
civicnewb's Avatar
i used something i probably shouldn't have lol... i used asbestos....
Old Dec 16, 2010
  #166
Lol, as long as you keep it wet when you work with it, you're fine
Old Dec 16, 2010
  #167
MindBomber's Avatar
Umm.. It'll work, but like xRiceboyx said you need to keep it wet when you work with it. I've worked with asbestos many times but its dangerous..
You should add, custom asbestos gaskets to your mod list lol.
Old Dec 16, 2010
  #168
that was a HUGE precaution when I was in the Navy, just because a lot of **** on our carrier still used asbestos, and working in the power plant/engine room, we're most likely to run into the stuff
Old Dec 16, 2010
  #169
civicnewb's Avatar
im totally adding that to my sig! good idea!
Old Dec 16, 2010
  #170
or a lock washer?
^ That's is what I mean by locknut.
This is a locknut...
I could not find the ideal pic. There are other kinds that are all metal instead of having that little poly ring in there, that would stand the heat better.
Old Dec 16, 2010
  #171
Be most careful with asbestos when you are cutting it or shaving it. That is when the fibers separate and can be inhaled.
Old Dec 16, 2010
  #172
civicnewb's Avatar
there now its in my sig
Old Dec 16, 2010
  #173
the locking part is plastic or similar... don't think they will survive a turbo...
Take the darned adaptor to a machine shop and machine it down... so you have more space for the bolts, or just re-thread them, or just weld everything together...
Old Dec 16, 2010
  #174
Wow. Did you read my post at all? I said that they make ones without the plastic (poly) ring that will stand high heat!
Old Dec 16, 2010
  #175
doh! me
sorry, too many posts are making hard to keep up.
Old Dec 16, 2010
  #176
MindBomber's Avatar
I literally throw my clothes away after working with asbestos, of course, you guys aren't covered in it head to toe like I am.. I really need a new job..
When you eventually paint the car, please post a thread in our new paint and auto-body forum. I'm whoring it out to everyone, so every falls in love with it and Triz keeps it!
Old Dec 17, 2010
  #177
civicnewb's Avatar
i will keep that in my mind... bomber
AND sda as i said... i can do all my fab work... i have already fabed up the adaptor... it can't be changed in any way
P.S Thank you ever so kindly for the bad rep..(whoever it was) and thanks EVEN more to anyone that has had a hand in helping in my project
Old Dec 17, 2010
  #178
Sense you are using an asbestos gasket. You should use lead paint too! lol
Old Dec 17, 2010
  #179
civicnewb's Avatar
man that would be epic!! but now that were on the topic of paint... i was thinking a candy apple red with metal flake for a glitter look?
Old Dec 17, 2010
  #180
Move the whole turbo lower?
thanks more to anyone that has had a hand in helping in my project
don't forget to give good rep to them
good job on editing your post
