Drivers side door actuator disassembly
Old 04-30-2012
ngm
ngm's Avatar
ngm is an unknown quantity at this point
Greetings, my power door locks on my 350K 1993 Civic LX quit working. The driver side door actuator has an Omron 20D micro switch inside that's broken. I'm gonna go to a local junkyard and get another actuator and either try the entire actuator or just the micro switch. Hopefully that will fix the actuator issue. However, could the control box that sits in the door also be bad?. It's got 12V and ground ok but with the actuator disconnected when I move the door lock switch I don't hear any of the relays in the box click. Could the box also be bad? I know the door lock switch is good.
Thanks
numbersguy
Electrical DIY
09-15-2018 11:24 PM
Youngciviboy
06-10-2015 03:49 AM
ashlava71
05-16-2015 12:54 PM
vgon24
05-12-2015 09:16 PM
Macko
Exterior
11-19-2001 10:34 PM
Quick Reply: Drivers side door actuator disassembly
