Log In
Register
Forums
Honda Civics by Generation
11th Generation Civic 2022+
GENERAL
HIDs and Retrofitting
Wheels and Tires
Detailing
MARKETPLACE
the *new* Civic Marketplace
Buy, Sell, & Trade - Archive
Transaction Feedback
OFF TOPIC
Photography & Videography
Legal Questions and the Law
LOCAL/GEOGRAPHIC FORUMS
California
Mid West
South
North East
Mid Atlantic
Canada West
SITE STUFF
Site News
Site Tips and Tricks
Gallery
Tools
Car Payment Calculator
Tire Rim Calculator
Vin Decoder
Members List
Live Feed
Marketplace
Vendor Directory
Become a Vendor
the CivicForums Marketplace
New Posts
View Dark Mode
Log In
Register
Threads
Google
Threads
Posts
Advanced
View First Unread
Log In
Register
Dark Mode
Contact Us
Manage Preferences
Archive
Advertising
Cookie Policy
Privacy Statement
Terms of Service
Your Privacy Choices
Affiliate Disclosure
Log In
Forgot your Password?
Terms of Use
and
Privacy Policy
or
Login with Facebook
Brake rotor rubbing against my caliper bracket.
Notices
Post Wheel, Tire & Brake related modification information and/or questions here
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Tag Search
Advanced Search
Find All Liked Posts
Go to Page...
Subscribe
silentz
1 Post
Hey guys,
I was changing my right axle and noticed my rotor is rubbing against the caliper bracket. Unfortunately, I drove it a very short distance before I realized it.
I took the new axle out and put the old axle back in with the old axle nut and it still rubs. Wheel bearing spins fine and smooth.
Here are the pictures.
http://imgur.com/a/OjSXH
Any idea would be greatly appreciated. I'm at a lost here
Thanks everybody.
Like
silentz
View Public Profile
Find More Posts by silentz
View iTrader Profile
06-24-2017
sdaidoji
Received 1,440 Likes on
338
Re: Brake rotor rubbing against my caliper bracket.
seized slider pins?
lub the hell out of them
Like
sdaidoji
View Public Profile
Find More Posts by sdaidoji
06-24-2017
ezone
493
I assume the rotor is rubbed all the way around evenly?
Did you set the car down or roll it without the axle bolted in the knuckle?
Or did you forget to tighten the big nut the first time?
How tight did you torque it?
Seems like the hub may have moved outward to make the rotor rub, I can picture the hub trying to move out of the bearing if the axle wasn't installed, or if the axle nut wasn't tight.
Like
ezone
View Public Profile
Visit ezone's homepage!
Find More Posts by ezone
06-25-2017
silentz
1 Post
Quote:
Originally Posted by
ezone
Yea, the first time i forgot to tighten he axle nut. Then I tighten it and still rubs.
I brought it to a shop near me and they pushed the wheel hub and bearing back in and it still rubs for some reason.
Any idea?
Like
silentz
View Public Profile
06-26-2017
ezone
493
silentz
Any idea?
Well we've nailed down the origin of the problem, and the problem is contained within the knuckle/bearing/hub area. What happened amongst those parts that's causing the rotor or hub to be in an incorrect location?
Like
ezone
View Public Profile
06-26-2017
silentz
1 Post
ezone
I think the bracket might have bent when I drove it out of the drive way wihtout completely tighten the axle nut. I'll have to take off the hub assembly on the other side and compare them sometime this week and report back.
Like
silentz
View Public Profile
06-26-2017
ezone
493
I seriously doubt the brake bracket got bent. If it bent it would have bent outward to give the rotor more room as it was pushed outward and grinding.
I think that for some reason, some part of the bearing/hub/rotor has moved outward and it hasn't been found yet.
Did anyone ever replace the wheel bearing in that corner and forget to install the snap ring retainer?
Like
ezone
View Public Profile
06-27-2017
silentz
1 Post
ezone
It was working fine before I decided to replace the axle because it clicks too much when turning. I owned this car for 17 years and haven't replace the bearing yet because it is still good when I spin them.
I spun the rotor to see if it got bent during the process and it spun straight.
Hmmm..this is very weird for me. I haven't take the other side out and compare yet, maybe in a few days when I have time.
Like
silentz
View Public Profile
07-02-2017
silentz
1 Post
OK. This is really simple to fix and I feel like a dunce after I figured it out.
See those washers on the bolts? They don't go on the bolts, they go between the caliper bracket and the hub assembly and you slot the bolt through them.
Hope your problem is the same as mine. Good luck!
Like
silentz
View Public Profile
07-02-2017
ezone
493
If this is true, then someone has changed something during the cars life to not quite stock, because the factory didn't put washers between the bracket and the steering knuckle.
Now that you mention the washers, IIRC the factory didn't put washers on those bolts at all......
Is the other side assembled the same way?
Like
ezone
View Public Profile
07-03-2017
silentz
1 Post
ezone
I took the other side out and it doesn't have the washer. It seems like the right is not original because I tried to fit the rotor from the left side and it wont fit because it is a bit smaller. I'm just glad I can drive it again instead of taking the bus for 2hrs each way to work.
Thanks for the help ezone. I really appreciated.
Like
silentz
View Public Profile
07-03-2017
ezone
493
silentz
So someone was sold a completely wrong brake rotor, but went ahead and used it anyway even though they had to hack a modification so the wrong part could be used---- instead of just going back to the parts store and swapping for the correct part?
Like
ezone
View Public Profile
07-06-2017
silentz
1 Post
ezone
This seems likely to be the situation here. Either way, I'm happy it is fixed and running properly now.
Like
silentz
View Public Profile
Subscribe
Tags
brake
caliper
rotor
rubbing
Back to Subforum
View Next Unread
Rear bearing leak?
Show Printable Version
Advanced Search
Email this Page
Advanced Search
Closed Thread
Share
Facebook
Twitter
Reddit
First
Prev
Next
Last
10:55 AM
LinkBack
LinkBack URL
About LinkBacks
