Dealer says I need new shocks & springs for '94 VX.
Rep Power: 0 Dealer says I need new shocks & springs for '94 VX.
I brought my '94 Civic VX into the Honda dealership last week for a slightly wobbling wheel (I slid on the snow and slammed into a curb). They said that the lower control arm didn't look bent, so they are going to check the alignment in a few days. They said that the springs and shocks were worn out. It has 141,000 miles on it. I haven't noticed any problems with the springs or shocks (I've owned it since 1994) but I suppose they could be worn out. How can I tell?
I also read that the timing belt should be replaced before it breaks. It still has the original timing belt. Maybe I should have the water pump replaced too?? Any suggestions of other things that might need replacing? I replaced the oxygen sensor and it has new plugs/wires/distributor cap/rotor. Not much else has been done to it over the years except for brakes and a clutch. Still gets close to 50 mpg. Great car!
Prelude Owner
Re: Dealer says I need new shocks & springs for '94 VX.
If you push down on the back or front of the car it shouldn't bounce more then once. Open the trunk and push down were the bumper meets the trunk. The car should go down then come back up and stay. They could be bad because of the mileage but unless there bouncy or leaking I wouldn't worry about them. You should definatly do the timming belt and water pump. They should have been done at 90k.
Replace the timing belt NOW! 90K is the recommended time, if it breaks your engine is gone. When they do that, they will do the water pump at the same time. I just replaced my shocks at 380,000 miles. I did it my self, about $130 a shock. If you want to sell your car, my phone is 512 293 9203. All I want is no rust and an AC!
I doubt the springs are worn... I really doubt it... although it may need shocks/struts... they are simple to replace... If you need a spring compressor, O'reilly will let you use theirs with a deposit, which you get back when you return it. The VX is very hard to find these days. I have one and I wouldn't even think of selling it. The gas mileage is as good or better than hybrids and they are fairly zippy. They have a go-cart feel to them when driving. = )
Edit: I just noticed the original post is a month old. I guess it's probably fixed by now. LOL
09-26-2023 06:44 PM
honda.lioness
16
02-10-2017 10:53 PM
