93 Del Sol electrical problem
Old Feb 16, 2012
svilledelsol's Avatar
svilledelsol is an unknown quantity at this point
Background: I have a 1993 Del Sol that won't start. The engine turns over but won't stay on once the key is released. It runs fine if the key is held all the way to start, but I haven't been driving it like this except to get it home from the mechanic.
The mechanic thought it needed a new distributor, and maybe it does, but on a hunch I took out the main relay to have a look at the solder joints. Sure enough, several were dry and cracked all the way around. Thinking that might be the problem, I resoldered them - I'm no professional, but reasonable competent with an iron - and put the relay back in.
Now: I turn the key for the first time in two months, but all I get is a faint whir from the starter. So either the battery is dead - because the car sat for 2 months in winter, and the battery's already pretty old (seems reasonable, yeah?) - or I shorted something out on the relay, although I *really* doubt it because I checked my soldering carefully.
So here's my question: I want to just jump start the car, to see if the soldering fixed the initial problem, but I'm concerned: if I *did* short out something on the relay, is there any chance that the current from jumping the car damage any other components?
I'd really appreciate any tips or suggestions. Thanks!
CarStuff
Dec 6, 2020 12:52 PM
steveneddy
May 19, 2015 02:39 PM
ywgflyer
May 15, 2015 05:05 PM
Andy
Dec 29, 2001 07:32 AM
Elusiv1
Oct 19, 2001 10:02 PM
