Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
Which to pick? for engine
Old Apr 1, 2013
JWalkin's Avatar
JWalkin is an unknown quantity at this point
I have a 1997 Honda civic Ex with a stock motor and i am wanting to swap but not sure which would be best.
http://www.hmotorsonline.com/shop/sc...age&item=30005
or
http://www.hmotorsonline.com/shop/sc...age&item=30025
Old Apr 3, 2013
wileycoyote0022's Avatar
wileycoyote0022 is an unknown quantity at this point
Re: Which to pick? for engine
There is a major difference between the two, one is essentially just motor, manifolds, fuel rail, and alternator. (this one)
The second is more of what your wanting to get for a couple of reasons, one you are running a D series motor, now someone correct me if I am wrong but motor series has to run along with the transmission series (unless your buy a converter, usually only done with H and F motors). Two, since you are converting to a B series motor a lot of the D series items dont bolt right up, hints why they call it a complete change over. (this one) http://www.hmotorsonline.com/shop/sc...age&item=30005
Unless this dealer is super close to you, I would do some more searching for JDM motors. If you can find one close to you and save yourself the shipping it would be most beneficial (save you a few hundred). Plus they are a little pricey. I just did a quick search and found two more (complete swaps) for 2100 and 1900. Dont settle do some shopping. Google is your friend, pull up Google Maps and search for JDM motors. Youll find some places close to you.
Two places I found cheaper
http://www.sunrisejdmmotors.com/
http://www.shopjdmstar.com/product/b16a-1st-gen-obd0/
Old Apr 6, 2013
JWalkin's Avatar
Thank you so much :P like i said i am all new to this. i wish i could make everything a B series because i here you can do much more with B then you can D.
F1wanabe
Apr 27, 2015 11:06 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
