B16b build (swap into 98 civic dx)
Rep Power: 0 B16b build (swap into 98 civic dx)
So I've been researching and I have decided to swap in the b16b type r into my civic as opposed to the b18c type r for a more well balanced and high revving engine. Now my plan is to turbo the car as well. I will be doing it right the first time and will be rebuilding the internals so that it can handle high hp . I need help finding the brands and well all the parts I will need to install. I understand I will need the following key engine components:
- Aftermarket pistons and rods
- head studs
- sleeves and seals
- clutch
- flywheel
- valve springs
what else is key? and what are good brands? any input is appreciated. Thanks
- head studs
- sleeves and seals
- clutch
- flywheel
- valve springs
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
OptimisticWay
05-12-2015 01:30 PM
Touge
04-26-2015 11:58 PM
Touge
Ottawa
04-26-2015 11:57 PM
