2000 Civic EX Coupe Lowering Questions
Old 11-28-2013
Yoda_17's Avatar
Yoda_17 is an unknown quantity at this point
Ok so im looking at lowering my Honda and need to know do i have to get the Camber kit front & rear, toe links rear if im going with Eibachs Sport Plus kit 41840680 that drops only 1.6 frt & rear? Also would 205x50x15 be a good tire set up for this kit & not rub or any suggestions would be Nice. New to this game use to Running Big Lifted TRUCKS lol!!! So any help would be GREATLY APPRECIATED from all you that have done it. Thanks Josh
Old 11-29-2013
Received 1,440 Likes on 1,196 Posts
Re: 2000 Civic EX Coupe Lowering Questions
you really start needing camber recovery adjustment below 2" in 7th gen, i do believe 6th gen is similar.
though the 6th gen is lower from factory
Old 11-29-2013
rustycivic's Avatar
rustycivic is on a distinguished road
With a 1.6in drop, no camber kits are needed. And with 6th Gen Civics, since they utilize a double wishbone suspension, there is no need for toe adjustment kit (There is adjustment built into the front suspension, and no one makes them for the rear, since toe doesn't change with lowering.
Just make sure to get the car aligned a week or so after the suspension is installed, to allow time for the springs to settle.
And that tire size should fit perfectly if your wheels aren't too wide.
Old 11-30-2013
Yoda_17's Avatar
Sweet thanks so much guys!!!
Old 12-03-2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
this is incorrect, at least with 5-6th gen civic's, lowering WILL cause the toe to be incorrect in which terms a rear kit will be needed to correct it. There is a factory adjustment (5-6th gen) that can be SLIGHTLY adjusted.
rcolosi
04-29-2015 07:48 PM
Civicman92296
04-23-2015 09:22 PM
shawe90
04-14-2015 07:10 PM
tattedlariat
04-12-2015 07:55 PM
silvervtec01
11-04-2001 06:56 PM
Quick Reply: 2000 Civic EX Coupe Lowering Questions
