Engine mounts
Rep Power: 0 Engine mounts
I have extreme wheel hop in my 1997 civic LX 5 speed, the engine mounts all are really old, and look fragile from the elements, and have stretch and tear marks on them, which all makes for an interesting ride on MN snow/ice.
I was basically wondering what is a good solution to significantly reduce the wheel hop and performance of the mounts without any more or much more than the normal stock vibration, it is my DD after all, I don't want it to feel like I'm in the rails in stop and go traffic, lol.
Live for the Twisties
Rep Power: 260 Re: Engine mounts
You could use this DIY and drill holes in them to adjust to a stiffness your happy with.
https://www.civicforums.com/forums/1...-bushings.html
Re: Engine mounts
Your best best would be to buy Energy Suspension motor mount inserts. To reduce engine movement, the rear mount would probably be the best one to use the insert, however this one would probably transfer the most vibration throughout the car. However with only one insert, it probably won't be terrible.
To reduce wheel hop, the two engine torque mounts found under the power steering engine bracket and also the front edge of the trans would probably be most effective. Those alone won't transfer a lot of vibration throughout the car..
Re: Engine mounts
Three things you did wrong:
1. You're asking about your 7th gen Civic Engine in the 6th gen Suspension section. (Wrong generation, wrong subforum)
2. You've co-opted someone elses thread about their bushings by asking an unrelated question. Next time ask it in a follow up in one of your own threads, or start a new post (in the correct place).
3. You've asked the same question, identically, twice in two different places. I've answered your question fully here: https://www.civicforums.com/forums/3...ml#post4538688
Re: Engine mounts
turbo_coupe_EJ1
Rep Power: 0 Re: Engine mounts
wheel hop is usually caused by old bushings but if you want to replace motor mounts the 2 lower ones to the front of the motor will be your best bet
streetglower123
04-12-2015 10:56 AM
