ES bushings worth it?
Rep Power: 242 ES bushings worth it?
Well, I've got a very loose inner LCA bushing but Honda doesn't sell individual LCA bushings for my year. I'm not sure why. I have the option of going with an ES kit from autozone but I'm worried it's going to make a really ruff ride. If that's the case, do you guys know where I can get OEM-style bushings?
Also, am I going to need a special tool to remove and install them?
Rep Power: 787 Re: ES bushings worth it?
front lca bushings do not have any effect on ride quality. that is based on springs/shocks. i have ES lca bushings and the cornering at high speeds is a huge improvement. the only "negative" i guess would be they squeak in the winter but only when going over bumps or dips in the road. in the summer, they are as quiet as oem rubber. i will never use rubber again, and prolly wont have to since these es bushings should outlast the car. the bushings need to be pressed on, i believe theres a diy somewhere around here but you need special tools.
Rep Power: 242 Re: ES bushings worth it?
And what about the prothane ones. Do they use lube and prone to squeeking or is it just ES?
idk, mine were black es bushing. it came with lube but it wears off quickly. my "kit" came with 4 bushings for the front of the car, two per side on the control arm. i just had sears install it for around $250.
i got mine from nipponpower, i think this is the kit.
http://www.nipponpower.com/product.phtml?p=321&mmk=392
Yeah, that's the equivelant of the 16.3114G kit for the 6th gen. G stands for graphite. I ordered a kit earlier today in the morning, but I chose red. I'm going to go back and re-order black. Thanks for the info.
So is it a big deal if the lube runs out?
well it only lasted a month in the winter snow, now it just makes creaking sounds. i know its the bushings so im used to it. but only when its cold and you go over big dips or bumps or up a steep driveway. most driving you will not notice anything. the lube is just to keep the noise down, otherwise the bushings do not need it to function properly.
big difference, esp since the oems were torn to shreds at 60k miles. the car holds turns much better now when in some areas ive had to slow down with the old broken bushings. its a great upgrade and beats putting oem rubber back that will just tear again.
1 Post
Rep Power: 364 Re: ES bushings worth it?
I have these bushings too, black, dont hear any squeeking ever- they are nice upgrade that you can feel and nobody can see. If you live in a high theft neighborhood you dont have to worry about these being stolen kuz of the PITA they are to get them in/out, but thats the case with any bushings like this.
1 Post
Rep Power: 266 Re: ES bushings worth it?
Cool, I'm looking forward to installing them. (that was a lie) I'm going ot have to use a press to press these in right? Also, do you guys know off hand if the spring/shock come out as one piece or will I need the spring holder tool? I need to remove them to get to the UCA wishbone to replace those bushings as well.
1 Post
Whoops, I forgot the reinforce I was joking, lol.. Testing... testing... can anyone sense humor without a line ending in "LOL"?
Press- yes, you can make a home made one, or just take it to a shop to have them press them in for you- they might even do it for free. And yes, all 4 corners come off the chassis as one giant ugly looking "coilover". UCA wishbone.... you mean LCA wishbone?? Which bushings exactly?
I don't get it. After I remove the sleeve and rubber, I have to remove the outer metal bushing sphere right?
Update: Just looked at the ES instructions. The metal sleeve needs to be removed for the 6th gen, but not on the UCA.
Rep Power: 228 Re: ES bushings worth it?
Well I installed them. What a bitch that was. I was expecting the ES bushings to pop in place by hand, but only the LCA inner bushings did. The UCA bushings had to be pressed in and all I had was a vise so it was pain. In fact I had to sand some off the entry point because they looked like they would explode before they went into the sleeve. ES really needs to redesign those.
All in all they feel nice. The ride is a little bit rougher and lounder and the car is more stiff over bumps, but more solid with better handling. Shiftings is easier and I notice and increase in responsiveness.
jackoncruzpr
09-29-2015 07:59 PM
ThatGuy913
09-28-2015 05:35 PM
beanhead
09-24-2015 12:04 PM
TheRiddicles
09-21-2015 01:28 AM
