No spark
Rep Power: 0 No spark
Need some help, my friend told me to change coil, so I changed igniter and coil and car ran great, then I parked it outside for a while at my sister's house when I went to get it didn't want to start😣 so I checked and had no spark again so I just brought a hole new distributor so I still not getting spark, so I checked getting power to distributor but no spark any help will be appreciated
Dr Krieger of Modification
Re: No spark
-no spark? or weak spark?
-Did you try jumping the battery? since it sat the battery could be dead, or low enough that it will hardly spark.
Re: No spark
Did your purchase an OEM or aftermarket distributor? Aftermarket's usually don't work well for these engines. Was the coil and igniter OEM (TEC or Hitachi)?
FrankenCivic
1 Post
Rep Power: 0 Re: No spark
could possibly be the crank position sensor...or even the ignition switch...obviously start from the plugs and work your way back...crappy parts make for a crappy day...you've already replaced the distributor so we would love to rule that out however...the problem may still lie right there...when you put the new one on did you try to make sure the distributor timing was right...ignition timing...same same...ish....
carter
28
09-26-2010 03:24 PM
JCurry2885
03-19-2008 11:01 PM
drunkenmagnum
Engine Swaps
28
10-12-2005 12:44 PM
