honda civic 1997 lx wont start . eld problem?
Old 03-21-2014
matteblackcivic's Avatar
matteblackcivic is an unknown quantity at this point
I was having very rough idling problems lately .
also , cluster lights dimming and radio was turning on and off .
eventually when I turned off the car , it wouldn't start up .
tow truck guy gave me a jumper the car turned on almost instantly . then it wouldn't turn back on .
I have a code for the ELD
where can I get this part ? also can some one provide a picture showing were the engine wire harness is located? thanks any info would help !
Old 03-21-2014
Re: honda civic 1997 lx wont start . eld problem?
Battery sounds run down, alternator probably isn't charging.
You shouldn't need an ELD.
How many other codes are there?
See if fuse #15 is blown.
Check out this bulletin: http://www.tegger.com/hondafaq/misc/...%2315_fuse.pdf
Old 03-22-2014
I checked fuse 15 and it looks like there is burnt signs on it . so the eld is not the culprit?
Old 03-22-2014
I bought this battery like a month ago .
Old 03-22-2014
Can you identify a blown fuse?
(Not just oxidized and brownish on the blades, but blown)
If the fuse is blown, the alternator cannot charge, and your battery runs down.
And it can set a pile of codes because a bunch of other stuff needs that same fuse too. It may or may not set some of the possible codes, not all items are tested at all times.
The bulletin tells about one known and likely cause of this fuse blowing and how to fix it.
Read the bulletin. Fuse 15 supplies power to several important items, the ELD is just one of them.
Doesn't matter. If it has been run down, it needs charged back up and tested.
HTH
Old 03-22-2014
IPerfect ,i just bought the fuse .if i were to jump the battery with my sister car would it mess her car up ?
Old 03-22-2014
Not if you do everything correctly.
If you do something wrong you can screw a lot of stuff up, maybe even disable both of the cars.
See how quickly that fuse blows again.
Old 03-22-2014
Correct me if im wrong . Park the car in front of eachother . Put the cables on the battery terminals. Then start up the opposite car and then ill turn mines on .
Old 03-22-2014
Every man should know how to jump start a dead car battery.
^^That's a link^^
Old 03-22-2014
Ok good news i changed the fuse jump startd the car. Everything works fine . But it acts like its bogging out now . What could it be ?
Old 03-22-2014
Is the alternator working now?
Voltage check?
Headlights bright?
Or did it blow the fuse again already?
Old 03-22-2014
yes , the car is running , speedometer is working perfect , I just checked the fuse its fine hasn't blown . i haven't checked lighting as the sun is still out . i'll get back to you on that in a new few . thanks a million . i truly hope this fix the problem .
Old 03-22-2014
If you don't find and fix what causes the fuse to blow, it is very likely to happen again very soon.
Old 03-22-2014
I read the tsb about the problem with wireharnes making contact with the intake manifold bracket . How do you fix that? It doesnt seem to be ripped or broken .
Old 03-22-2014
All it takes is a pinhole rubbed through a wire insulation and touching grounded metal. Sometimes these are damn near invisible.
ANY of the 20 wires (or whatever #) in that bundle can be the problem.
The bulletin explains the repair.
HTH
Old 03-22-2014
Going to make sure to check those wires thoroughly in the morning .i forgot to mention that all these electrical problems started happening when i changed out the o2 sensors. The cable of the one in the bottom is hanging not tie wrapped
Old 03-22-2014
Might just be coincidence, or maybe the blown fuse caused O2 sensor codes (both sensors also share that same fuse).
As long as nothing has damaged the dangling wire, I doubt it could cause the fuse to blow.
CarStuff
12-06-2020 12:52 PM
jessicakaybby
04-20-2015 12:11 PM
civic_gt
04-19-2015 08:15 AM
CascadiaBlue
04-18-2015 09:13 AM
dooner24
04-14-2015 07:51 PM
Quick Reply: honda civic 1997 lx wont start . eld problem?
