interior dome light does not work
Old 04-15-2013
david5300's Avatar
david5300 is an unknown quantity at this point
My daughters 97 Civic DX cabin light quit. The bulb is ok but I can not find the #30 fuse to check. I have pulled each 7 1/2 amp fuse under the dash and visualy inspected it. All looked ok.
I checked the wiring at the door switch and there was no current.
If it was a bad wire it would have blown a fuse?
Where else can I check?
Thank you in advance.
Old 04-15-2013
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner's Avatar
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: interior dome light does not work
Did it quit all together or does it work via the switch and not door or door but not switch etc etc...
Old 04-15-2013
Gunner's Avatar
Check under hood fuse #43
ORskier
05-03-2015 12:54 PM
twtron
04-17-2015 12:09 AM
wawacito
11-05-2001 03:32 PM
meels808
11-05-2001 09:15 AM
TropiKalCiviC
09-25-2001 07:02 PM
Quick Reply: interior dome light does not work
