Nuts for battery terminals?
Rep Power: 163 Nuts for battery terminals?
Hey so I know the honda part number for the regular nuts for the battery terminals (32602-SK7-900), but does anybody know what the thread type and size is so I can find nuts at Parkrose hardware or something?
I have 2 ring terminals for accessories that I put on the posts with nuts and the nuts aren't going to last forever, pretty chewed up.
I want nuts that aren't as deep as the stock nuts so the stock nut for tightening the circle to the post, the 2 ring terminals and this additional nut will all fit on that screw thing on the + and -.
Maybe super tight high temperature zip ties would do the trick
Rep Power: 163 Re: Nuts for battery terminals?
I think I'll just get some straight barrel brass with tin plating battery terminals from wiringproducts.com and crimp them on and get longer bolts and more nuts from my hardware store.
Normal 6 x 1.0 mm is the thread size on the original terminal clamps. Length can be whatever you need.
Lord Sin
Rep Power: 0 Re: Nuts for battery terminals?
Why not just replace your terminals. You can also just take you old hardware to the hardware store and the can help you with the size and thread
manfredww1
08-17-2015 08:04 AM
WaryDriver
08-08-2015 05:08 PM
Smokahontas123
07-22-2015 10:07 PM
07-12-2015 11:54 AM
