97 Civic LX Cluster to 03 Civic LX Cluster
Old May 29, 2007
mdawg's Avatar
mdawg is on a distinguished road
Basicly like the title said im swapping these clusters out, I need some good diagrams and tuts would also be helpfull from other peoples swaps. If anyone has some info to help me out that would be great thanks!
Old May 30, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
Re: 97 Civic LX Cluster to 03 Civic LX Cluster
hmm thats quite a hard one man ... Y dont u do the 04 05 civic cluster swap ??? much better and Im sellin one ... :-)
Old May 30, 2007
my bad !!! I read ur post wrong .. I thought u were putting a 97 cluster ON a 03 civic :-p
Old May 30, 2007
mdawg's Avatar
Yeah, Plus I already have the cluster...which I scored for $50 Im just having trouble finding a wiring diagram of the 03 Cluster.
Old May 31, 2007
electric130's Avatar
good deal!
mani.....take notes j/k
Old May 31, 2007
lol hahahah i know im dumb
Old May 31, 2007
mdawg's Avatar
Ok for the life of me I can not find a layed out wiring diagram for the 03 civic cluster, can someone PLEASE help me out here?
Old May 31, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Enjoy.
File Type: pdf
File Type: pdf
Old May 31, 2007
mdawg's Avatar
You are my hero, Thank you SO much!
Old Jun 1, 2007
mdawg's Avatar
Im having a little trouble reading how this is layed out bro. I dont understand it enough to figure out every wire. I have them all for my cluster and what each wire does but on this diagram I dont. Any tips and help is appreciated thanks!
Old Jun 2, 2007
mdawg's Avatar
bump bump bump...come one someone has to know something.
Old Jun 3, 2007
Sorry man, I think I gave you all the help I can. This is what DIYing is all about.
Old Jun 3, 2007
mdawg's Avatar
Yeah but your diagram doesent really show me what the wires do its not a pinout diagram or anything. I appreciate the help its what I asked for but now Im trying to find another source so I can get this hooked up. I called honda and they said they coudlent even tell me what the pins went to so I dont know what to do.
Old Jun 4, 2007
mdawg's Avatar
Ok, So I took some guessing today and start hooking wires on the diagram. Turns out that my diagram of my cluster is really close but the 03 Cluster is Not. I started with the turn signal, I hooked it up into where I thought it was on the 03 cluster and the check engine light comes on. I turn my signal just to check and sure enough the check engine light starts flashing(lol). So I try every other pin on the blue harness which controls the left turn signal and nothing. Just to get the engine light to work I had to hook the yellow wire up on the green harness that is labeld "power". Im going to asume that there is another power hookup on the cluster? Because I hooked that same wire to all of them on the blue harness and just got the Engine, Oil, Park, Nutral, Reverse light to work was about it. I also thought that the gauge lights were on the blue harness also but nothing ever came on, I couldent even get the tach so Im having a really hard time just because I cant find a good layout of the 03 Cluster can anyone help?
Old Jun 6, 2007
mdawg's Avatar
Ok, so Im not too sure if this is going to work judging by the wiring diagram. The only gauge that it shows by itself on the 03 is the gas gauge. Im not sure what some of these wires mean that just say fuse and all that but by the looks of it, this wont work but someone please correct me.
See Below
ID:	71366   Click image for larger version
Old Jun 11, 2007
mdawg's Avatar
Alright, I went in today and tryed one last thing. I have turn signals working, gauge lights, fuel gauges, tach., The only problem I have now is the spedometer and the temp and odometer(havant messed with it yet so it might not be a problem). Anyway the wire on the 03 cluster they all go into is the same color. All the gauges hook into it, it seems. What can I do about this?
Old Jun 15, 2007
mdawg's Avatar
Ok I have everything working that I really need except Spedometer, Odo, and Temp. When the car is on is it just sending a certain voltage to the motor of them to make them move? Could I possible tie straight into the motors?
Old Dec 17, 2007
mdawg's Avatar
Long Time Update:
Decided to give it one last try and what do you know...it works! Ill get pics up soon but the only thing I have not figured out is the temp gauges but Ill see what I can do to fix that later.
jonavin
73
Oct 4, 2004 07:18 PM
Inspired2k1
Nov 15, 2001 07:37 PM
brill
Nov 12, 2001 07:29 PM
WeRkX
Nov 1, 2001 10:33 PM
CivicBR900EX
Jul 23, 2001 03:20 AM
