Front brake pad grinding?
Old 01-19-2018
cmendoza21's Avatar
cmendoza21 is an unknown quantity at this point
Question Front brake pad grinding?
I was in the passenger seat of my own car after getting picked up and noticed that every time the driver pressed the brakes I could hear a grinding noise coming from the passenger side front wheel. I'm pretty sure its my brake pads, which I will be changing within the next day. My question is, do I have to change the rear drum brakes all at the same time when I change the front brake pads? I will also be inspecting the front rotors and checking for any unevenly worn areas or webbing of the rotors.
Let me know if it is absolutely necessary for me to change the rear drum brakes as well.
Old 01-19-2018
CraigW's Avatar
Re: Front brake pad grinding?
Most rear drum brakes will out live the car.
Old 01-19-2018
Colin42's Avatar
Received 1,120 Likes on 935 Posts
it would be worth popping the drums off and giving them a clean and lube, shouldn't need to replace anything on the rear though
Old 01-19-2018
CraigW's Avatar
^^ And, all of my latest Civics.... the drums slid right off easily.
Old 01-19-2018
cmendoza21's Avatar
So spray the cylinder/springs in the drum brake assembly with brake cleaner right? Is it the same with the lube? What lube would you recommend? Like a silicon lubricant?
Old 01-19-2018
cmendoza21's Avatar
So if I replace the old brake pads with the new ones they will have a thicker pad obviously since they're new, so if I apply the brakes would the brake pads make contact before the drum brakes, leading to them wearing out faster? Maybe I'm just overthinking the way the brake system works.
Old 01-19-2018
CraigW's Avatar
^^^ They likely will not be that much thicker over what you have on it currently.
Old 01-19-2018
Colin42's Avatar
spray the whole assembly and the drum with brake clean.
for lube I use silicone paste in the areas where the shoes contact the pads and the threads of the adjuster
easiest with the shoes removed, do one side at a time so you have a reference when you reassemble, taking pictures can help too
the fronts do about 80% of the work anyways, the brakes are self adjusting
Old 01-19-2018
Colin42's Avatar
I don't get so lucky up here in Canada, luckily the drums have those threaded holes in them
rhvic
05-22-2015 03:06 PM
Kennykid2002
7th Gen Do It Yourself Articles
07-29-2012 01:00 AM
Grey
17
02-21-2004 06:21 PM
CapYoda
03-31-2003 02:54 PM
Grey
15
02-17-2002 11:38 AM
Quick Reply: Front brake pad grinding?
