Grinding Sound When Braking
Rep Power: 0 Grinding Sound When Braking
I have a really bad grinding sound when I am braking. I checked the front breaks and rotors and noticed both axles needed to be replaced. I replaced them thinking this was the source of the grinding sound. The rotors are smooth and the breaks are still thick enough I think to not need replacement.
The grinding sound can be heard when I drive at speeds below 30 MPH.
What might I the neophyte mechanic might have missed?
Car: 1997 Honda Civic LX four doors.
Thanks, in advance
Thanks, in advance
Re: Grinding Sound When Braking
Is the grind sound coming from the front, or the rear?
Your first post never said which.
Received 1,146 Likes
Rep Power: 485 Re: Grinding Sound When Braking
The inner brake pads, highly unlikely you can diagnose how thick the pads are. On my 02, had a bit of uneven wear, and the inner pads were wearing much faster than the outer, resulting in a terrible grinding noise.
It's just 2 14mm (I think, at least, for the size) bolts holding the caliper on. Remove and do a physical inspection of the pads. Alternatively, if the grinding is that bad, there could be metal on metal (i.e. backing plate and rotor) contact (like ezone suggested) and there'd likely be visible damage to the inner surface of the rotor. Pull the wheel and run your finger on the backside of the rotor. If it feels anything but nice and smooth, you pretty much got your answer.
Rep Power: 0 Re: Grinding Sound When Braking
Upon further inspection it was the back part of the driver side front brake. The part difficult to see towards the engine for the beginner mechanics. I replaced the rotor on the driver side only. Because of the uneven wear I wonder if I have drag and something else is failing?
Wear indicator tab (squealer) has broken off, that means it was trying to tell you it's worn out for some time while the squeal noise was ignored (turned the radio up?)
How do the other 3 pads look?
Slide pins are free, not stuck?
Other 3 pads are freely movable, not stuck in the bracket?
