Black soot from exhaust 99lx
#31
Rep Power: 0 Re: Black soot from exhaust 99lx
Well, I'm really hoping I found what is causing the fuel trim issue...
I started up the car tonight and it hasn't been started since yesterday, so it was a cold start. I checked the fuel trim once it went to closed loop and STFT was at 14% roughly.
I pulled and plugged my vacuum line from the fuel pressure regulator and instantly the STFT dropped to 4-5%, and once the car was fully warm, the STFT was at 0-2%, right where I believe they should be.
So, would everyone agree that my pressure regulator is bad? (I'm hoping it is so that this issue is finally solved).
Side note: I did do a pressure test a while back, and had 37 psi with the vacuum line hooked up, and 43 psi with it disconnected, but I neglected to rev the engine at all with the gauge hooked up and I didn't let it sit long after I shut the car down before disconnecting. The pressure held for the 5 or so minutes after the car was off. Looking back, I know I should have left it on longer to see if I had a pressure drop.
#32
Well, my issue is solved. It turned out to be my fuel pressure regulator even though I was within spec with the car running at idle. I neglected to check how long I held pressure after shutting the car down though.
I pulled my vac line off the regulator while watching my stft, and it went perfect. So yesterday I was able to get a junkyard regulator off a 98 accord and my stft was at 5-6% on an ice cold start, and once the car was fully warm stft was at 1.9-3%.
Only question I now have is are the regulators different between the accord and civic? I know the accord was a 2.3l. While my stft was perfect at idle, while running highway speeds (70mph) my stft was running -7% roughly the whole time. Is that because made to give enough pressure to a 2.3l engine so my ecu was cutting back? I'll try to get my hands on a regulator from a y7 and see what happens.
#34
#35
I still need to rent the pressure tester check again. Do you know the differences in regulators between civic and accord? I could just be seeing an improvement in my fuel trims due to the injectors recieving more psi.
At idle my stft is perfect, but cruising I'm running between -5 to -3%
#36
So it seems you just installed a new problem that kinda masks the original problem
#37
Today I was able to swap on a fuel rail with injectors and pressure regulator and I noticed something odd. The car I swapped them from had fuel in the return line and mine did not. It was from a '97 Y7 in great mechanical condition. Is that normal or is it possible I have a fault somewhere along my return line? Aside from that, I saw fairly improved STFT at 7-8%. Those components had 150k on them. I also tried just the pressure regulator on my rail with my injectors and that didn't change anything from what I've been seeing.
#38
Ok, that makes sense.
hard to speculate about a return line, Was there still vacuum in the fuel tank?
#39
Not sure if it's related, but I very rarely hear a vacuum "hiss" when I open my gas cap. I do only if the car has run for a minute or two and I open right after I shut it down, otherwise nothing when I stop to fuel up.
#40
what exactly do you mean by vacuum in the tank?
abrahamtennyson
05-30-2017 10:10 PM
hayden55
07-02-2015 06:12 PM
puckman1325
06-10-2013 02:20 AM
texas-longhorn
36
01-14-2013 12:45 PM
