1999 Civic EX Cylinder 4 misfire issue
Rep Power: 0 1999 Civic EX Cylinder 4 misfire issue
I have a 1999 Civic EX completely stock, I get code P0304 Cylinder 4 Misfire only after engine is at temp and i restart 0-30 min later.
This all started when i purchased new battery at the Auto Parts store and restarted car.
While misfire is occurring i can pull #4 plug and verify spark present.
While Misfire is occurring i can rev motor 5-10 sec and misfire symptoms go away. I do notice some times a little bit of smoke followed by raw gas smell from exhaust
This is very repeatable, If i restart before engine is at operating temp no problems.
I have swapped injector 4 with injector 3, Misfire stayed on #4 cylinder
I have replaced and or cleaned the following
New NGK Plugs
New NGK Wires
New Distributor Cap
Swapped Distributor with know good one
Compression Good on all cylinders
Head Gasket Replaced 2 years ago
Cleaned IAC
Cleaned throttle body
Oil change
Freeze Frame Data
Code P0304
ABSLT TPS 9.4%
Eng Speed 722 RPM
Calc Load 34.1%
Map 9.7%
Coolant 203 degf
IAT 117 deg f
ST FTRM1 -5.5%
LT FTRM1 0.0%
VEH Speed 0 MPH
Fuel SYS 1 Closed
Fueld SYS 2 n/a
New NGK Plugs
New NGK Wires
New Distributor Cap
Cleaned IAC
Oil change
Freeze Frame Data
Code P0304
ABSLT TPS 9.4%
Eng Speed 722 RPM
Calc Load 34.1%
Map 9.7%
Coolant 203 degf
IAT 117 deg f
ST FTRM1 -5.5%
LT FTRM1 0.0%
VEH Speed 0 MPH
Fuel SYS 1 Closed
Fueld SYS 2 n/a
Re: 1999 Civic EX Cylinder 4 misfire issue
Valve adjustment?
See if it's been losing coolant very slowly?
Make it misfire....Shut it off before the miss stops happening. Remove spark plug from that cylinder that misses, figure out if it is wet and what it is wet with (antifreeze?)
Rep Power: 0 Re: 1999 Civic EX Cylinder 4 misfire issue
Thanks for the advice! I checked #4 plug in the syquence you asked. It is moist with a strong smell of gas. no signs or smell of antifreeze that I noticed.
all other plugs look normal
I checked all intake and exhaust valve clearances they are within spec.
On a another note I have noticed after a long drive the coolent overflow is boiling over. It lasts about 5 min after car is turned off. I have replaced radiator cap which helped a little. Could this be a failed thermostat symptom? Or water pump? Or related to the misfire
Could this possibly be a main relay issue. Ambient temp has been 90+ days?
The overflow looks like it's boiling -- and the radiator is actually low.
It's blown the head gasket.
That explains why it misses.
Thanks for the reply,
Today i burped coolant by attaching a funnel to radiator neck and allowed rad fan to come on a few times. i added about 1 quart of coolant during the process. once full i did not notice anything odd like gasses pushing through coolant.
let care sit for 5 min
restarted car it started and immediately died, started again and it started but had a very low idle around 400 RPM but did not stall
pushed on the gas pedal and revved just fine and returned to normal idle
i did not notice a misfire but CEL did come on, checked code and Misfire on #4 cylinder
repeated the test and attached the #4 spark plug pic. no evidence of coolant on spark plug visual and or taste test.
Do you still think head gasket? would you recommend any other test to clearly identify head gasket before i tare it down.
Coolant will enter the cylinder to get the plug wet as it sits with pressure on the cooling system.
A dribble collects then when you crank it over it splashes the plug and it won't fire until it can dry off. Meanwhile the fuel that doesn't burn collects on the plug too.Fuel makes a lot more odor than coolant.
See this thread link, read the info in the first post and note it contains two videos. See the second video. That is my go to test on this particular design.
https://www.civicforums.com/forums/3...reference.html
Another way
If you have a cooling system pressure tester you could get it all warmed up, open the system and install tester, apply 15 psi pressure and let it sit overnight (would have to keep pumping it back up during cooldown), then check for the evidence (coolant) to have appeared in the suspect cylinder.
100% head or headgasket. I have been fighting the SAME issue on my 2000 LX. Replaced everything, swapped injectors, adjusted and adjusted. Tossed a can of stop-leak in the radiator because I really didnt care at this point. Next day it hot starts fine and drivability is awesome. Soooooo.. New head on order with all gaskets. I already shaved the warped original head about 2 years ago. 200K on the clock so Ill get a new reman head.
bobinyelm
07-31-2017 11:43 AM
whitelight75
07-08-2014 09:08 PM
mike98
01-12-2012 10:06 AM
