Integra B20B high idle
Old 03-15-2018
Jonnyboyy80's Avatar
Jonnyboyy80 is an unknown quantity at this point
I replaced my ls with a B20B I know that it doesn’t have a crankshaft sensor because it’s jdm. I put an oil pump from an ls in it. It has a blox intake and throttle body on it. When you first start it up it idles around 1500 rpm when it warms up around 900 and when driving is where it gets weird. So in gear it’s fine when I push the clutch in the rpm jumps to anywhere between 2500, and 3000 until I come to a complete stop then it will drop down to 1500. I kinda at a stuck point don’t know what to do I checked all vacuum lines and everything seems fine. Friend owns a shop so we smoked it and it was fine.
Old 03-17-2018
D17VTECPOWER's Avatar
D17VTECPOWER is a jewel in the roughD17VTECPOWER is a jewel in the roughD17VTECPOWER is a jewel in the rough
Re: Integra B20B high idle
What year is it? Does it have any codes? As long as it runs good otherwise, the IACV is the first thing I would check. If you have an extra OEM throttle body, I would suggest putting it on and see if it helps.
Old 03-17-2018
No check engine and I did take off the throttle body put the oem one on same thing. I cleaned the iacv and nothing has changed
Old 03-17-2018
What year is it?
Old 03-18-2018
It’s a 99 integra, last night was driving and ran into something else also. I scanned it and got a baro code. I did was I was suppose to and it drove a lot better.rpm for idle was 900 when driving the issue still occurred it went to 2500 - 3000 and I shut the car off turned it on and the idle shot up to 1500 again.
Old 03-18-2018
What ECU are you using? Is it the stock ECU, or did you change it to the B20 ECU?
Old 03-18-2018
Dr Krieger of Modification
mac25's Avatar
Old 03-19-2018
Sorry for late answer but it is the b1 ecu p75
Old 03-19-2018
I bet the ECU isn't running the engine correctly. How could it? The engine you installed is 10% larger than what the ECU is programmed to run. Based on the way a speed density tune works, the amount of airflow is calculated by MAP readings, barometric pressure, RPM, and air temp, and a bigger engine will move more air at the same RPM and manifold pressure, so it would make sense that you would get a baro code. The fuel and spark maps will be different too. You need to get the correct ECU for the engine if you want it to run properly. The ECU still thinks it's running a B18.
Old 03-19-2018
I’ve seen on many forums that the b1 ecu s work with it but I guess I don’t have a choice didn’t really think about it I’ll order one if I have any issues I will message back thanks
Old 03-19-2018
Received 1,440 Likes on 1,196 Posts
huh... coming from someone not running the correct ECU in his own car...
Old 03-19-2018
True. However, I changed my engine to an identical one besides having VTEC. Also, I tried to change to the correct ECU, but the dealer couldn't flash the immobilizer for some reason, as I posted about before. The other thing is my ECU isn't causing a problem, unlike his.
Klaula86
10-24-2017 07:02 AM
Chicho Alonzo
04-13-2017 02:33 PM
freyes23
06-21-2015 10:37 AM
TylerBower
11-14-2009 11:34 PM
sk8ter4life
08-01-2005 01:34 AM
Quick Reply: Integra B20B high idle
