09 civic rear door will not open using inside or out handle
Old 12-07-2018
nuxbag's Avatar
nuxbag is an unknown quantity at this point
One min it was working fine and now neither handle works to open the door. I tried to get the inside handle off but since I don't know how it goes together I'm afraid to brake it. any ideas?
Old 12-07-2018
Colin42's Avatar
Received 1,126 Likes on 941 Posts
Re: 09 civic rear door will not open using inside or out handle
You're going to have to get the door panel off, you may damage it removing with the door closed but you can get another one at a junkyard for pretty cheap, or if you have a slim Jim or call a tow truck driver they may be able to pop it open, not sure though
Old 12-14-2018
Dr Krieger of Modification
mac25's Avatar
Not sure on that modle but on the 7th gen you can remove the interior handle without removing the door skin. This let's you access the mechanical pull wire that opens the door.
if you're lucky the connection from the interior handle to the pull wire slipped/broke off, and you'll be able to open the door but pulling directly on the pull wire.
should take a Phillip's, a flat head and a beer to complete.
good luck.
Old 12-15-2018
nuxbag's Avatar
good luck.
I have tried to remove it , but its not coming easy and I dont want to brake it. I just tried the door and it works fine now. any ideas on that?
Old 12-15-2018
Colin42's Avatar
Lube the hell out of it and keep an eye on it
yacovdavid
08-20-2016 01:11 PM
johnnyrooskie
07-18-2012 09:55 PM
carvedtop
05-28-2012 01:20 PM
psycroll
06-19-2009 02:41 AM
hustlelikem0fo
01-09-2005 06:27 PM
Quick Reply: 09 civic rear door will not open using inside or out handle
