wiring amp to fuse box instead of battery
Old 12-03-2002
srfdog88's Avatar
srfdog88 is an unknown quantity at this point
I just got a new amp installed a couple of weeks ago. They wired the positive wire to the fuse box in the engine bay by conecting it to the left screw in the middle of the front of the fuse box. My other amp is wired to the positive terminal on the battery. Ever since then my idle has been a lot lower at times escpescially when i run my stereo for extended periods of time. My car has not died but it goes to baout 500 and then catches itself and then goes back to about 600-650. before thismy car used to idle ay around 700. Does wiring the positve wire to the fuse box make any sense and could it affect my idle. there is enough slack to wire it to the terminla but will that make a difference. i have never seen this done before. one last question, if I were to switch the wire to the terminal what battery conections do I have to disconect, and would it be better for me to buy i new terminal adapter with more outlets rtather than using the stock one becasue i would have 2 different amp woires going to it.
Old 12-03-2002
Turbo Guru
andyman97's Avatar
I'd make it simple....run one wire from the battery and get a fuse distribution block.
Old 12-03-2002
tbone323's Avatar
tbone323 is an unknown quantity at this point
who did your instal, BEst Buy? LOL {sounds so}
Fuse Dist. blocks are nice, BUT becareful. If you run a live wire from your hood all the way to your trunk (where most ppl mount the dist block) and you somehow sever the wire at ANY point between the battery and the dist block, BYE-BYE battery, KA-BOOM!! It's recommended that you have a fuse with 18" of the battery, so you'll blow your fuse, not your battery. ANd get that **** outta the car's fuse box man, thats ridiculous!!
~Tbone
Old 12-03-2002
i boogie for the raindrops
LudlamTheory's Avatar
honestly, it shouldnt matter, the alternator, the battery, and the fuse box are all wired to the same place anyways...
Old 12-03-2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
Hmmm... it shouldn't affect your engine. Maybe it was a coincidence. You might wanna get your engine checked out if this is the case.
Old 12-04-2002
Turbo Guru
andyman97's Avatar
Quote
[hr]Originally posted by: tbone323
If you run a live wire from your hood all the way to your trunk (where most ppl mount the dist block) and you somehow sever the wire at ANY point between the battery and the dist block, BYE-BYE battery, KA-BOOM!! It's recommended that you have a fuse with 18" of the battery, so you'll blow your fuse, not your battery. ~Tbone[hr]
Absolutely...no question about that (have to remember not everyone knows these little things.)
Old 12-04-2002
tbone323's Avatar
Quote
[hr]Originally posted by: LudlamTheory
honestly, it shouldnt matter, the alternator, the battery, and the fuse box are all wired to the same place anyways...[hr]
Nooooooo, this is why you see cars on the side of the road in flames!!! You are correct in saying that they all are connected to the same place BUT, I will GUARANTEE that your amplifier will draw WAAAAAAy more current that any of the wiures in your fuse box was designed to carry.
Why does the fire department carry al those huge hoses? Why don't they just use those small garden hoses everyone already has? See my point?
I think the late Chris Farley said it best..."Fat man, little coat!"
You put too many electrons thru a thin wire, that wire gets hot due to all of the friction between the moving electrons and the static molecules in the wire and in the BEST case, you don't get all of the performance that your amp is capable of. The WORST case, your car starts on fire!
don't be lazy, re-wire it OR, bettrer yet, take it back to the shop and bitch to the manager!!
~Tbone
Old 12-04-2002
srfdog88's Avatar
thanks everyone, i didn't think it was right for the amp wire to start at the fuse box in under the hood. Yes there is a fuse 5 inches aftwer it is starts but the wire should start at the battery, i will fix it but do i disconnect the battery wires before a switch?
Old 12-04-2002
tbone323's Avatar
it's very good practice to disconnect the battery before working with ANY wires in your car that are responsible for power.
Old 12-18-2002
GooseEX's Avatar
GooseEX is an unknown quantity at this point
Definately Disconnect before working with your power, don't leave room for for accidents.
Old 12-18-2002
FaintReality's Avatar
FaintReality is an unknown quantity at this point
Disconnect the negative battery terminal, run the power wire from the amp directly to the positive battery terminal with an inline fuse as close as possible to the battery, then reconnect the negative battery terminal.
Old 01-28-2018
John Manus's Avatar
John Manus is an unknown quantity at this point
Re: wiring amp to fuse box instead of battery
Ok so some of these posts are true to a certain extent as a auto rebuilder i can tell you that most cars today have a jump start post on the fuse block the big red wire comes straight from the battery you can use this its not like you're amp is going to pull more than what the battery has to offer and as far as ground you can hook it to any bracket bolt that bolts to the engine as it is grounded out to the frame same as battery however if you're idle is changing its because you're altinator cant keep up its a honda not a peterbuilt you need a compassitor for this issue or a secound battery in the trunk which will require a altinator upgrade or you can just hook to battery and ride around like these idiots with the bass hitting and lighting dimming now that can cause a fire but the positive terminal on your fuse block is big enough to handle anything your amp needs remember auto is dc not ac things are different in the dc world
Old 01-28-2018
Prelude Owner
GolNat's Avatar
Wow this is an old thread!!!!
roverben
01-21-2019 05:16 PM
wankers
01-20-2019 06:44 PM
MiniMi
05-27-2015 01:57 PM
twtron
04-17-2015 12:09 AM
smmahan
04-15-2015 08:17 PM
Quick Reply: wiring amp to fuse box instead of battery
