02 civic Key light not lightining
Rep Power: 0 02 civic Key light not lightining
I bought a 02 civic for 200 bucks awhile back 1.7 vtec auto when your turn the key the green light does not show up on the dash tried looking up the same issue and seems like everyone has problem with it staying on anf flashing what do i need to do so its starts again ive only had egs before
Re: 02 civic Key light not lightining
Try the other key.
Possible that current key is not being recognized by the immobilizer system and is cutting fuel to engine.
Rep Power: 0 Re: 02 civic Key light not lightining
[QUOTE=NDNV;4754053]Try the other key.
Possible that current key is not being recognized by the immobilizer system and is cutting fuel to engine.[/QUOTE only got one key with the car
Follow a (good) wiring diagram. Test. See that the immobilizer CU is powering up and has ground.
Fuses in both fuseboxes are involved (so check ALL of them) and main relays are involved in supplying power to the immobi CU.
There's a lot more to it than that, but there's a starting point to work with.
Green key symbol does not light up at all? Immobilizer CU controls that light.
If that's all that was checked, YOU better recheck every fuse in the car yourself, because you're really starting from square one.
If someone had to PAY for diag, they had better have received the correct answers as to what it takes to solve the problem. And prices.
/dead serious
I hope someone didn't PAY for such a non-diagnosis like that.
/dead serious
/dead serious
Sometimes I wish I could get away with lame azz work like that, but I don't work that way. I know far too much.
Maybe fuses were all that mechanic knows how to check.
If that's all they know to check....maybe they don't even know how to do THAT right. (Parts replacers typically don't know a damn thing about troubleshooting real problems, lack critical thinking skills, and don't understand anything about basic electricity such as what makes a light bulb work)
You start from square one now. YOU need to make sure all fuses are in fact good.
If you had access to a known good part supply I'd suggest plugging in another immobilizer control unit and see if that makes the idiot light blink.
thumbelina
06-12-2019 08:42 AM
Harley Findd
05-18-2017 06:12 PM
iceman_1227
08-27-2011 10:54 PM
IrockCivics
01-19-2011 08:09 PM
philboy81
11-24-2009 06:16 PM
