2005 VP won't charge the battery
Rep Power: 0 2005 VP won't charge the battery
the battery is less then a year old. The battery light started flickering and the car went dead. I replaced the alternator. And now it won’t charge the battery.
I can keep the battery charged when its hooked up to jumper cables. But as soon as I remove the cables. The battery starts losing voltage and the car dies again.
Re: 2005 VP won't charge the battery
Ground issue somewhere? Check all chassis and engine grounds. Get alternator and battery yesterday at A-zone or other parts store.
Received 1,440 Likes
Rep Power: 338 Re: 2005 VP won't charge the battery
check fuse - the main one.
Also, loose bolts cause the alternator to not charge.
warning! loose bolts linked to ECU frying, so solve ASAP
Rep Power: 0 Re: 2005 VP won't charge the battery
I got it working. FINALLY. After numerous times of removing the powersteering pump and adjusting the belt it started working. First the belt was to tight. Then to loose. Finally got it.
power steering? Not the alternator?
Rep Power: 0 Thread
Tim Lade
01-05-2017 10:58 PM
desk0
15
11-09-2011 10:20 PM
The RedheadPimp
07-06-2009 11:41 AM
