2005 Civic: all backlight buttons dead
I have a 2005 Civic Hybrid, and have a big problem.
Aside from the instrument cluster, EVERY backlit button and control on the dash does not light up when the lights are turned on.
The buttons/***** do activate the required components when pushed/turned.
This includes the Cruise button, radio, Temp controls, hazard, AT shift indicator lights, etc.
If pushed, the Cruise, Recirc, Fresh, and Economy button backlights do come on as required.
About 5 years ago, one little bulb, behind the Cruise button went out and I replaced it.
So here's the problem. I can see one, maybe two bulbs going out, but ALL of them?
Is this a tell-tale sign of a widespread electrical problem?
I just replaced the 12v battery, and the lights were like this before and after.
And I did check the illumination adjustment control on the instrument cluster.
The owner's manual doesn't show a fuse for something like "backlight illumination."
Can anyone help me figure out what's wrong with my car?
Re: 2005 Civic: all backlight buttons dead
Many of us recommend replacing headlight bulbs in pairs for the same reason.
Pretty simple to test a couple of the suspect bulbs and test power/ground to those bulbs.
Went thru the manual again and was surprised that I over looked it: a fuse under the hood marked "Small light." I popped it out and sure enough, it was blown.
Don't know why I didn't see it the first time. All is back to normal.
