Weird Door Lock Behavior
Old 01-15-2017
Brian Bills's Avatar
Brian Bills is an unknown quantity at this point
Over the past couple weeks I've noticed some weird door lock behavior that I'm hoping to get some pointers on.
Looks like with either the fob or the master door lock I can reliably lock/unlock all the doors but the drivers door. With the drivers door about 75% of the time I can unlock it while only about 25% of the time does it lock. If I listen carefully I can hear the relay in the door trigger but the lock does not respond.
I have replaced batteries in the fobs and charged the car battery (which is only a few months old).
Any ideas?
Old 01-15-2017
Re: Weird Door Lock Behavior
Weak power lock motor?
Old 03-17-2018
Hey guys, I'm still struggling with this issue...
Looks like all of the power door locks are tying to respond but only the rear driver side is reliable. E.g. I can her the relay firing to raise/lower the lock but it's not strong enough to fully lock/unlock.
Any help would be greatly appreciated!
Old 03-17-2018
Slumpertcivic's Avatar
Did you ever replace the weak motor on your drivers door?
Old 03-17-2018
I didn't because it seemed like all of the doors were struggling not just the drivers door. I'm guessing theirs a bad ground or something...
Old 03-17-2018
Time to open up the drivers door.. Try unplugging the driver door motor and see if that solves your other doors not working right.
If the motor is jammed up, it may be drawing too much current to allow the other motors to work right. It’s a common circuit.
Old 03-17-2018
I'll give that a try right now. Thanks!
Old 03-17-2018
OK...pulled the drivers side door panel off and disconnected the driver door lock motor (there were two connectors) and the locking behavior hasn't changed. The rear driver side door seems to be perfectly responsive but the other two doors are intermittent/weak.
While the driver door is disconnected is the next step to do the same to the passenger door? Then to the passenger rear door?
Old 03-17-2018
I've got all the door lock motors disconnected with the exception of the rear drivers side (which seems to be functioning properly consistently). I then plug in any one of the three other doors and get the same response (inconsistenty/weak).
I'm guessing there's a relay somewhere that I could try replacing?
Any other ideas while I have the car torn apart?
Thanks!
Old 03-17-2018
The one that still works is the good one.
The others that barely try are bad. Replace all of them.
Old 03-17-2018
How do 3 actuators die at the same time?
Old 03-17-2018
They are all the same age and have been operated about the same number of times.......Why didn't the 4th one die too? Has it already been replaced?
Old 03-17-2018
Well it's looking like your theory may have some creditability...
I went ahead and ordered the other thee actuators but while I'm waiting I removed the good actuator (from the rear drivers side) and plugged it into the passenger rear side and it still works like a champ. I guess the wiring/relay are OK then; at least to the rear passenger door.
I'll update things when the new actuators arrive.
Old 03-17-2018
310civicEX's Avatar
310civicEX is an unknown quantity at this point
easy install.. save all white clips or go to junkyard and get a pocket full.
Old 03-18-2018
It wasn't a theory at all LOL
Old 03-19-2018
Looks like replacing all 3 door lock actuators solved my problems!!!
Thank you all for your help.
