Civic Door Tweeters
Civic Door Tweeters
Hi, I am checking my wiring harness setup in an attempt to figure out why my 02 Civic Ex door tweeters are not working since I have added a new deck. I believe I have wired everything color wise correctly.
Could this be related to my wiring harness or deck not supporting that many speakers ?
Thanks
Thanks
1 Post
Rep Power: 170 Re: Civic Door Tweeters
If you didn't touch anything speaker wise, they should work fine. Did they work correctly before the head unit swap?
The tweeters and door speakers are tied together. There is one set of wires that goes from the head unit to the set of speakers. They split from there sending signal to each one.
Ok, I am less concerned about the tweeters anymore and now I cannot get my deck to turn on. I have rechecked the wires and after not changing anything from the way they were before.
I saw a spark when I removed the deck coming from one of the wires making contact with another (wiring harness).
I have checked my fuses (all) and they do not look seared or blown(broken in the center) so I am not sure what is causing the issue.
Also my door locks only work when I the car is on. Does that help narrow down the problem. Any help would be appreciated . Thanks
Is it possible that fuses could not work with out looking blown?
Also I have two ground wires. One coming from the deck itself and another from the wiring harness attached with a butt connector. I have connected them both to a screw on the chassis and at another time, taped one and attached the other to the chasis. Which way is ideal?
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
18
08-04-2021 01:28 PM
