Stuck Rew Button on Radio
Rep Power: 0 Stuck Rew Button on Radio
Ok I been doing some searching and this particular thing doesn't seem to be anywhere on the board, but maybe someone out there has had a similar experience. I have to input the radio code as I disconnected the battery to clean the terminals, I know the code but the #1 button(rew) doesn't register and I need it. Has anyone popped the buttons off and back on or solved a similar problem, I've already sprayed some contact cleaner around the button but not sure if it's getting anywhere near the actual contacts.
Rep Power: 131 Re: Stuck Rew Button on Radio
just dug my stock unit out of the closet and it doesn't seem that the face want's to come off very easy. It looks like if you remove the radio, then remove the *****, then you can pop the face off and might be able to get to the buttons.
Or grab a BT radio while you have it out and put that back in instead.
Civic720
09-10-2015 10:06 AM
jpat21
09-03-2015 11:32 PM
hatch90
09-03-2015 08:45 AM
msaeger
09-02-2015 08:47 AM
