Need somewhat expert help. ES1 & ES2 Owners only
Old 03-05-2014
JDMxES1's Avatar
JDMxES1 is an unknown quantity at this point
Alright so I have a 2001 honda civic 4 door. Can someone help me with something I really want to mount 2 6.5 speakers into the Rear Doors. They will be mounted how they are mounted on the front (twords the front of the door on the bottom) I'm not worried about wiring. I need help with mounting is there way to install them mounted behind the door panel or is had to mounted ontop of the panel I really need help with this one.
Old 03-06-2014
Prelude Owner
GolNat's Avatar
Re: Need somewhat expert help. ES1 & ES2 Owners only
I would Mount them in the door, and use a front speaker cover from a junk yard car as a door cover for the rear. You are going to have to make a custom mounting bracket, or use the front door bracket and stay with the smaller speakers.
Old 03-10-2014
JDMxES1's Avatar
Question Re: Need somewhat expert help. ES1 & ES2 Owners only
Thank you , def try this cause I do have an extra door panel to cut up
Old 03-11-2014
lowlife9's Avatar
also a larger magnet mite interfere with the windows.
Old 05-13-2014
JDMxES1's Avatar
Well sorry for not updating this. I went to the junkyard got 2 door panels for 5$. My initial Idea was to put a hole in the metal frame of the door just like the front. On further inspection I noticed that it was to close to the window so I ended up making the hole on the door panel it self. I mounted an 8" Audiopipe 250watt component speaker. When I got through the cutting out I realized that the magnet touched the metal part of the door. I ended up cutting 2 rings out acting like extenders for the speakers trim to lay on and the lifting the magnet off the metal frame. I wish I can show you waht it looks like. But my now EX girlfriend slit my speakers so im awaiting on 2 brand new ones.
loosescrew84
16
08-11-2015 07:08 PM
cecisd15
08-11-2015 02:53 PM
mrwhos
08-11-2015 02:03 AM
jpandjf
08-03-2015 05:02 PM
Bounddyy
07-08-2015 11:22 AM
Quick Reply: Need somewhat expert help. ES1 & ES2 Owners only
