3rd Brake Light Problem
Rep Power: 155 3rd Brake Light Problem
So I recently removed the stock spoiler on my car becuase I think our cars look way better without the spoiler, but here in California we need to have a 3rd brake light and I wanted to know since I removed my spoiler which had the brake light on it, Is there a way where I can install a 3rd brake light somewhere?
Please, DubTee is my father, call me Dub
Rep Power: 0 Re: 3rd Brake Light Problem
Bottom of the rear window will be the place to go, if like sl33py said you don't already have one there. You can buy LED strips online or if you want something that looks more OEM you could probably use the third brake light off of a 2003-2005 Honda Accord, the model with the elongated horizontal tails; they integrated it into the trunk deck when they went to triangular tail lights. The angle of the rear window might not be exact but should be pretty close. When I had the windows tinted on my wife's Accord the installer mentioned removing the brake light and tinting between it and the window so you should be able remove one off of a junker and drill holes in the rear shelf of your car and mount it there. A local professional auto paint should be able to help you match a spray can of SEM interior paint to paint it to match.
Rep Power: 155 Re: 3rd Brake Light Problem
Yea this is how mine is rite now. So even if I do put a third brake light from another car the light will not go through because of it being blacked out in that area. Would it be possible to put a Red LED strip right above that area or something similar to OEM?
If you want to mount something on the outside of your trunk deck, something from here might work: http://www.watsons-streetworks.com/l...ke_lights.html
They have some billet framed lights that could be mounted on the back of your car.
There are some here that are designed to mount inside the window with no gap between the light source and the window: http://www.ronfrancis.com/products.asp?dept=25
I've never dealt with either of those vendors, just what I found on a quick google search.
Yea I just tapped into the old wiring. Finished installing it last night and it doesnt look bad. Thanks for all the help guys. One less thing I have to worry about getting pulled over for.
Xuhme
21
08-07-2023 03:40 PM
Touge
04-26-2015 11:59 PM
Touge
Ottawa
04-26-2015 11:58 PM
SSMatey
04-13-2015 06:09 PM
