Airbag Light ON
Rep Power: 0 Airbag Light ON
Guys, any suggestions on what could have caused my airbag light to go on. I unclicked my sitbelt and the airbag light went on on my dashboard. I have an appointment tomorrow at the dealership but im sure it will cost alot. Has this ever happened to anyone?
Live for the Twisties
Rep Power: 260 Re: Airbag Light ON
Our cars are known to have problems with the SRS lights, well basically all Honda/Acura because the system sometimes "hiccups" and causing codes to trip the SRS light.
DISCLAIMER: Please do this at your own risk, i am not responsible for any damages that you may cause by doing this SRS DIY reset. If you do not trust yourself, please take the car to Acura Dealership and have them reset it for you, Warranty will normally cover for reset at FREE of charge. Try this DIY at your own risk.
Note: If your airbag deployed or seats has been removed or anything that may have triggered the SRS, this DIY will not work for you. All you will get is two flashes or more and the light will remain on.
Tools Material Needed:
- Standard Paperclip (or wire)
- Maybe flash light (night job)
Time:
- 1 to 5 minutes
Difficulty:
* out of *****
Back up thread http://www.dc5nation.com/forums/showthread.php?t=44 incase pictures or whatever happens
First make sure your key is out of the ignition.
Step 1:
You can use two options in this step to use to make two contact connect together:
Paper Clip, you can use the paperclip and bend it out to where both ends are next to each other so it can be put in to two pins.
- or -
Regular wires, this is actually the best way to use to complete a circuit.
Step 2:
Remove the bottom panel under the dash, two twist clips which can be easily taken off. (turn counter-clockwise)
Step 3:
After the bottom panel is exposed, locate the fuse box (see drawing for location)
Step 4:
Locate the SRS plug above the fuses in the fuse box panel, you will see a yellow clip in the middle left side. It is also the ONLY plug thats yellow in the fuse box panel.
Step 5:
Unplug the clip. You should see two pin holes that you will be completing the circuit with using the paper clip or wires
Step 6:
plug the paperclip in to the 2-pin clip.
After all the Prep Work is done, here comes the steps you need to take to complete actually reset the light. TIMING MUST BE PERFECT, if the light comes back on, remove the key and repeat steps again. Read these steps first before attempting the reset.
Step 7:
With the paperclip or wires in the pins, place the key in and click to the Ingition On position II and leave it alone throughout the whole step.
Step 8:
You should hear beeps for 3 seconds, and when the beep is gone, the SRS should turn OFF.
Step 9:
QUICKLY, Take the paperclip/wires out and the light should come back on.
Step 10:
When the light comes on, QUICKLY plug the paperclip back in to complete the curcuit again, in a second or so, the SRS light should TURN off
Step 11:
At the final step here, you will remove the paperclip/wire and the light will quickly flash twice and turn off. You should wait a second or two to see if the light comes back, if so, YOU WILL NEED TO REPEAT steps 7-11 again. It will likely take at least 5 attempts to be successful. If not, read step 12.
Step 12:
At this point, take the key out of the ignition and put the 2-pin clip back in to the proper place (same place where you took it out). Secure the bottom dash back in to place. Test out the SRS again with the Ignition Position II. It should beep then the SRS should turn off.
Quick Read DIY without pictures:
1. connect clip to yellow clip, turn key to position II
2. wait for the light to go off and remove the paper clip/wire.
3. As soon as the light turns back on, quickly connect the circuit again.
4. The light should turn back off. Remove the paperclip/wire again.
5. The light will wait a second or two before it tells you the follow word.
6. Final word is, 2 quick flashes and SRS light turns off completely.
6-A. two quick flashes and the light remains, you may be too slow or you have a short in your SRS somewhere.
7. turn off ignition and put back the clip.
Congratulations, you have successfully reset your SRS light.
Troubleshoot:
Most of the errors can cause by removing items such as steering wheel, seats, seatbelts and airbags. Its very rare for a sensor in the front to go bad but if you have been in to an accident and your airbag didn't deploy but the seatbelt locked, YOU MUST replace the SRS module.
If you have aftermarket steering wheel or seats, there is a resistor that you can purchase from Radio Shack where you stick in between those where the airbag or seats suppose to be and act to complete the circuit.
For people that have aftermarket/Non-Airbag Seats, please read this guide to bypass the SRS light issue.
http://forums.clubrsx.com/showthread...ermarket+seats
NOTE: You will not hear the beep if you have your driver side seatbelt on.
Time:
- 1 to 5 minutes
Difficulty:
* out of *****
Step 1:
- or -
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Step 10:
Step 11:
Step 12:
Troubleshoot:
If the unlikely event that you are unsuccessful at clearing the codes, you can read the codes yourself to find out exactly what's wrong without having to pay the dealership.
While searching around on how to figure out why my SRS light was going on and off I found this site. Great information on how to manually read the SRS codes! So you don't have to give your money to the dealership!
DIY: SRS Codes and reading them
Thanks to R3dline from ClubRSX.com
Everything is the same except our OBDII port is rotated 180 degrees and will look like this,
If the problem is more than just a hiccup in the system, the light will turn back on and you should go to the dealer. These instructions are exactly what the technician will do to your car, except he has a paper clip tool made by Honda.
Kenny the Ricer
Re: Airbag Light ON
Moved to Electrical
I have the SRS Light on too. If it doesn't bother you, I left mines on, but thanks to Austin, I think I'll go check mine
Taking it to dealer, this will happen
-They will charge you $68 diagnostic fee, regardless of what they find
-If they find it to be faulty seatbelt, they will replace it for no charge under warranty (seatbelts have lifetime warranty)
-If they find it to be airbag system, they will charge you upwards of $200 on top of the $68 for airbag replacement
Rep Power: 266 Re: Airbag Light ON
mine was same as OP. got out of the car to get the mail one day. car still running, undo the seatbelt and SRS light comes on. i messed with resetting about 10 times. each time, the light came back with taking the seatbelt off. went to the dealership. they said if it was the buckle, everything would be free as they are lifetime warranty. sure enough, the buckle was bad. they had to order the part. i picked my car up next day and didn't pay a penny. car was 7 years old and had 130k miles on it. didn't matter. still under warranty.
Kenny the Ricer
Re: Airbag Light ON
They usually do
i know the guy who bought my car and the reciept from this should still be in the glove box. i can try to get a copy showing no fees if you want to show your dealer.
Whachya lookin at?
Rep Power: 289 Re: Airbag Light ON
They have the power to waive that diagnostic fee regardless. Just need to sweet talk them into it. I hate it how the dealer does everything in their power to screw you.
voblak2
20
05-04-2023 02:08 PM
Burnout
07-15-2022 10:24 PM
jimmyfloyd
05-20-2015 07:06 PM
