Alternator replaced - then radio stopped working
Old 11-09-2010
jkorte's Avatar
jkorte is an unknown quantity at this point
I've got a 2005 Limited Edition Civic EX with the 6-disc CD changer
Long story short, the dome light were left on, severely draining the battery. Jumped it, but didn't seem to be getting charged by the alternator and would eventually lose battery power and not re-start. Had Autozone fully charge the battery and then check the alternator, and the alternator seemed to be the issue.
Had the problem re-diagnosed as the alternator and then had it replaced this morning. After being installed, tech said the radio went on for 30 seconds and then died. I haven't gone to pick up the car yet, but they claim to have checked the fuses and can't seem to figure out the issue. Said they called the local Honda dealer and they were unfamiliar with the issue.
Any ideas?
Old 11-09-2010
jkorte's Avatar
Re: Alternator replaced - then radio stopped working
possibilities based on the little bit of internet research I have done:
1. radio shorted out due to wrong amps being used
2. wires touching somewhere
the shop said they would take care of the radio if it was determined to be their issue. during the jumping/charging of my battery the radio was fine, so it seems to be related to the replaced alternator.
Old 11-09-2010
jkorte's Avatar
update on the situation (and yes, I realize I'm talking to myself at this point):
Picked up the car, stereo will not turn on, is not asking for CODE, etc. What wasn't mentioned was that the power locks are(were) not working. Went into the store, came out, power locks are working. Went home, at lunch, left to go back to work, power locks aren't working.
I called the shop back and explained the new symptom which leads them to believe there is a bad connection that is contributing to a lack of power distribution. May be something that looks physically fine but for whatever reason isn't fully connected. Going to shoot back through after work and have them re-check it. Will report back.
Old 11-09-2010
Kenny the Ricer
Kennykid2002's Avatar
Make sure to check all terminals and adapters are plugged in, sounds like something is loose and/or becoming faulty
Recheck all your fuses yourself
Old 11-10-2010
jkorte's Avatar
thanks, will do.
Relatively sure that the power locking issue is the result of my remote starter needing to be re-programmed.
beyond the CD player just not turning on at all, though, my airbag indicator stays lit up now (great!)
Old 02-17-2013
gameboo's Avatar
gameboo is an unknown quantity at this point
I also have encountered this problem.
2004 Civic.
Just had alternator replaced. Now the radio has no power (doesn't turn on, no code request)... additionally, the clicker for the car worked the first time I used it after getting the car back, but now doesn't work. I can hear a click noise in the car when pressing it, but no action happens with the car.
Checked the internal fuses, I will check the ones under the hood tommorow. Any reason why changing the alternator would cause this?
I don't understand why the clicker would work once and then not work...
also, why would the cars radio stop working too??
Thank you,
Rich
Old 08-06-2016
xiek's Avatar
xiek is an unknown quantity at this point
Having this issue after replacing the alternator, I don't see any posted fixes though, did someone figure it out?
Old 08-06-2016
Blown fuses causing it to not turn on at all, or the radio needs a code to unlock?
Old 08-09-2016
xiek's Avatar
Nope there were no blown fuses, and the radio had no power to it.
Found it was the multiplex unit, replaced from a wrecker and everything returned, entered code and radio worked afterwards.
Just not sure how that unit failed by changing an alternator with a battery saver hooked up. Unless the battery saver energized something that normally was not energized.
Old 01-13-2019
dulceenvy's Avatar
dulceenvy is an unknown quantity at this point
did u still have to reprogram it after u got the new part?
BCiv03
10-22-2017 08:13 AM
msaeger
09-02-2015 08:47 AM
scientist_tz
07-12-2012 01:13 PM
Boost Addicted
Buy, Sell, & Trade - Archive
12-17-2009 05:46 AM
XSRCivic
01-04-2006 05:18 PM
Quick Reply: Alternator replaced - then radio stopped working
