rca and ground wires
Rep Power: 0 rca and ground wires
i ran my rca and ground wires down the passengers side door. i havent hooked my amp up yet but should i rerun the wires rca and ground wires so they are seperated? i dont really fell like redoing my wiring, but will it make a difference?.. any help would be appreciated. thanks guys
Rep Power: 0 which rca's did u get? depending on the maker (monster cable's the only way to go), if the shielding is good you shouldn't have a problem,,,worst thing that may happen is you might get some static or interference....
Rep Power: 0 ran a ground wire down the passenger side? in that case.. take everything you bought, put it back in the box.......
anyhoo.. you prolly meant remote wire.. the remote wire does not draw enough current to create a magnetic field strong enough to distort the sound travelling through the rca cable(s).
1 Post
Rep Power: 0 Your gonna have a some massive whining noise dude..[IMG]i/expressions/face-icon-small-smile.gif[/IMG].. and Monster cable isn't the only way to go.. Any Shielded RCA's with colt plated terminals are pretty much the same....but definately re-run those wires bro.
Cheers
Mohawk
Cheers
Mohawk
hondadriver95
07-13-2015 09:43 PM
07-12-2015 11:54 AM
JUNITO
07-09-2015 08:36 PM
CivicsClass101
07-09-2015 11:14 AM
robbie374
07-07-2015 02:56 AM
