4ohm amp doing 2ohm load?
Old 05-30-2006
Cypher's Avatar
Cypher is an unknown quantity at this point
would a 4 ohm amp be able to handle a 2 ohm load if its cooled with some fans so it doesnt overheat? i have a pioneer 2 channel and just found out it is only recommended for a 4 ohm load.
Old 05-30-2006
let the devil out
eye_see_you's Avatar
it is rated at 4 ohms for a technical reason if you run it at 2 ohms more than liekly no matter the cooling method it will overheat and shut down or go into a protection mode and need repair
Old 05-30-2006
05reverb's Avatar
05reverb is an unknown quantity at this point
^^^^yup, exactly what he said. it could be ran at 2 ohms without no problem, but after a certain point (loudness) it will go into protection or blow fuses. if you run it at 2 ohms and turn it up loud, more current that is allowed by the fuse and amp will be passing threw, so it will go into protection or blow the amp fuse.
Old 06-02-2006
Rufus's Avatar
Half the impedance, twice the power.
h4ldol
04-24-2017 08:16 PM
UltraHDGames
06-08-2016 05:16 PM
Mc7602
09-17-2015 02:01 PM
JMKendrick
09-16-2015 06:17 PM
redcloud
09-07-2015 01:45 PM
Quick Reply: 4ohm amp doing 2ohm load?
