anybody have a 15 inch subwoofer?
#31
Rep Power: 232 Re: anybody have a 15 inch subwoofer?
well with the technology fot subs today you can get one 12inch that sounds louder then one 15 or two twelve's ive even heard a single 8inch sub sound louder and smoother then two twelve's.
#32
What my consideration is taking this in mind that its 2004 civic almost 9 years old and fairly small car i dont want those 2 12inches to rattle my car lol (ofcourse my baby is getting older and weaker) .. again im not sure if that will happen and i want second opinion
#33
anyone know how are these subwoofers?
http://www.bestbuy.ca/en-CA/product/...rchPageIndex=1
#35
#36
because there complete and udder garbage bad sound quality and even worse reliability they will literally ''explode''. i would personally get this http://www.sonicelectronix.com/item_...s-Package.html
#37
#39
Prelude Owner
My single 8 inch Infinity Reference kicks ***! Better then the 2 10inch Pioneers I had. It can rattle my car but its turned down cause I don't like that.
Get a good quality amp and sub with properly matched ratings and sub box volume.
#40
So i ended up buying these subs
and now im looking for amps .. im considering these amps
http://www.sonicelectronix.com/item_...s-AR1500M.html ... how are they ?
Also if my sub has RMS power of 400 watts but total peak power of 1200 watts and i provide it with 700 watts through my amp will it blow my sub?
#41
Prelude Owner
The sub is rated at 400 rms at 4 ohms so you want an amp that puts out that. 700 is to high.
Amp should be rated between 75% and 150% of the subs rating.
#42
#45
http://www.sonicelectronix.com/item_...-KAC-7205.html
it says it gives me 500w if i bridge it to my subs...
#51
#52
Prelude Owner
Yea that will be good. 500W is plenty. You might have to upgrade your door speakers and/or headunit if you haven't already. My system is about 250W and my stock speakers have a hard time putting out enough power to blend with the sub. I had to turn the intensity on the amp down to compensate so its not as loud or intense as I would like it. The stock speakers crackle also when I turn it up past a certain point.
#53
#55
