Is heat damaging - amp question
Old Jun 17, 2003
cdmx's Avatar
Exclamation Is heat damaging - amp question
Ive got a rockford amp and its about 2 years old.
Today i touched it and it almost burned my fingers...Its getting so hot..I have it behind my single enclosure its a large single...and i guess its not getting enough air...Im trying to mount a computer fan...mabye it will help..
But is this heat damaging...Should i fix this problem immediately..or can my rockford handle it...Is it some sort of feature where the amp cuts off to prevent heat damage? because its doing that now.
Old Jun 17, 2003
LudlamTheory's Avatar
i boogie for the raindrops
really depends on how much heat it is. computer fan will work if you take of a cover, cop a hole in it, and mount the fan
Old Jun 17, 2003
tbone323's Avatar
tbone323 is an unknown quantity at this point
All Rockfod amps have thermal protection circuitry and if the amp gets too hot (as determined by the temperature ratings on the FET's) the amp will turn off.
~Tbone
Old Jun 17, 2003
cdmx's Avatar
I guess thats what its doing...So if i have a computer fan aiming to it, it should keep cooler for longer or stay on for longer..Correct?
or is the computer fan not blowing enough air to do so
Old Jun 17, 2003
tbone323's Avatar
well, if it doesn't ever turn off on you, i wouldn't go theu all the hastle with puttin a fan in
Old Jun 17, 2003
cdmx's Avatar
heh, it does turn off...if im in the car for a while bumpin real loud
Old Jun 17, 2003
tbone323's Avatar
yeah, that is the thermal protection turning on...what is the load impedance as seen by the amp? How long can you play your stereo before it turns off? I am VERY interetsed to know since we are in the design stages for 2004 RF amps and real world feedback is the BEST kind. Please desicribe your system, maybe even include a pic or drawing.
~Tbone
Old Jun 17, 2003
cdmx's Avatar
To be honest my system is not complete...Its rigged off the factory cd player:
From the factory cd player im getting the RCA signal from the front speakers. Im running 4awg wire from the battery to a distributor (originally it was for 2 amps) but now im just running an 8awg wire to the amp from the distributor... And i have a 8awg groud wire to the chassis....Im running the 500a2 RF amplifier (US version)...The amp is powering a JL Audio 12 W3 D4...the amplifier never used to turn off...The car i used to have i had the amplifier in the fender behind the carpet and it would turn off often...But this is the first time it cutoff in a while. Today i was running the system almost at full volume for about an hour till it cut off for about one minute and came back on.
btw i think the sub is 4 ohms
Old Jun 17, 2003
cdmx's Avatar
RF amps are the best, i would never buy anything else.
Excellent for their price.
Old Jun 17, 2003
tbone323's Avatar
yea, i'd try a fan, from what i can gather, your amp is in a small area of your trunk that doesn't have a lot of air circulation, try a fan, it may help or try moving the amp to where there'smore room for it to breath. sorry i can't help ya more, but w/o seeing it, this is about the best i can do
~Tbone
Old Jun 19, 2003
JAG609's Avatar
JAG609 is an unknown quantity at this point
extreme heat is damaging to all electronics. period.
thana
Jun 15, 2020 07:05 PM
mikemc422
Aug 9, 2018 05:41 PM
AngeloS
Jul 16, 2015 11:00 PM
Lopes101
Jun 7, 2015 08:04 PM
viper775
Dec 9, 2001 10:52 PM
