Civic 01 ground wires - Honda Civic Forum
Old 12-08-2018
alishrouf is an unknown quantity at this point
Hi to all
i need to know where is the ground wires for 01 honda civic
I think there is one near to the radiator
One under the fuse box
One under the right head light
If anyone know where is the other wires please help me
Thanks
alishrouf is offline
Old 12-08-2018
Administrative Rice. WAT?!
Re: Civic 01 ground wires
moved to correct subforum
1) battery to chassis (forward/under fuse box)
2) chassis (same point as #1) to tranny
3) chassis (upper radiator support) to engine (by upper radiator hose)
Now, if you're just looking for wherever random ground bolts are (where they grounded out various electrical components from the factory), they're all over the place. There is, indeed, one of those below the passenger headlight. There's also one under the center console. Another behind the rear trim piece in the trunk. Probably a bunch of other places I haven't looked or have forgotten. The aforementioned list is the "big 3" people upgrade.
xRiCeBoYx is offline
Old 12-09-2018
thank you very much dear
Old 12-10-2018
NDNV's Avatar
NDNV is on a distinguished road
NDNV is offline
Old 12-10-2018
The Grenadine Jellybean
thornygravy is an unknown quantity at this point
You upgrading em or? Just curious.
thornygravy is offline
Old 12-11-2018
I upgraded the ground wires yesterday but i don't know the way to upgrade the alternator wire in my 01 civic
some ppl says i can make a direct wire from the alternator to the battery and some of them says this will damage the battery because alternator will not stop charging the battery
Do u know how to upgrade it properly ??
Thanks
Old 12-11-2018
The latter is false, you can safely connect the positive from the alternator directly to the positive on the battery. (It's recommended to add a fuse.)
Just be careful, the positive pin on the alternator has a tendency to snap when trying to remove the nut.
Old 12-11-2018
How the alternator will stop charging when battery is full if its connected direct to the battery ??
do you mean the negative line is the responsible about cut the charging and connect it back when the battery full ??
sorry im newbie in this field pls explain
Thanks
Old 12-11-2018
It's necessary for the alternator to be charging the battery always, when the car is running.
Old 12-11-2018
thank you
Old 12-11-2018
D17VTECPOWER is a jewel in the roughD17VTECPOWER is a jewel in the roughD17VTECPOWER is a jewel in the rough
Thanks
When I upgraded my alternator positive cable 4 years ago, I connected the cable directly from the alternator positive to battery positive. No electrical issues here, and I moved my battery to the trunk 2 years ago. Good luck with your project!
D17VTECPOWER is offline
Old 12-12-2018
Thanks for sharing you experience
Appreciated
Old 12-12-2018
Appreciated
No problem
CivicPro01
03-05-2003 04:08 PM
MangoEX
01-06-2003 03:22 AM
ohiojosh78
01-03-2003 12:21 PM
RedDragon333
12-31-2002 01:08 PM
nochopstix
03-26-2002 07:15 PM
Quick Reply: Civic 01 ground wires
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
