2005 Civic EX SE coupe - which metra install kit?
Old Apr 25, 2010
Trauma's Avatar
Trauma is an unknown quantity at this point
Which head unit install kit for a single din do I need that works with the EX SE coupe?
Old Apr 26, 2010
EM2Newf's Avatar
EM2Newf is an unknown quantity at this point
Re: 2005 Civic EX SE coupe - which metra install kit?
This is the kit I used:
http://www.metraonline.com/products.aspx
My 2005 is not an EX but it is an SE, Canadian version. Should work for yours.
Also, pick up a harness so you don't have to cut the factory harness:
With that you can just take the harness for the aftermarket radio and connect it to the Metra harness outside of the car, then test fit and test radio functionality. If all is well then put everything back and you're good to go.
Old Apr 26, 2010
05EXSE's Avatar
Slow and Low
05EXSE is an unknown quantity at this point
+1
I have the same exact car wondering the same question. The above links are specified for what kit or harness you are talking about. Just redirects to the site. Please help and add any feedback or opinions. Thanks guys
Old Apr 27, 2010
EM2Newf's Avatar
Dash Kit: 99-7899
Harness: 70-1721
Just search for those numbers. Or you can search by vehicle and look at Kits & Harness Into Car.
These are for the EX 1.7 litre. The kits are the same for the DX/EX as the dash is the same.
The dash kit has the pocket below the headunit so you can throw stuff in there and the harness saves you from having to cut the factory wiring harness. It'll save you time and headaches.
I hope those help.
Old Apr 30, 2010
Trauma's Avatar
Mine has the factory 6-disc in-dash changer/MP3 player.
Don't we have to buy the dash panel version for the non-special edition so that these kits will work?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
usajags84
May 10, 2015 08:11 AM
twtron
Apr 17, 2015 12:09 AM
dano2005
Apr 14, 2015 01:58 AM
LexBoy
Nov 4, 2001 04:30 PM
