ebay fog lights 30 shipped, correction
Old 04-02-2009
streetthrowback's Avatar
streetthrowback should not be trusted
ok i guys i see thats their some people that are having problems so i just installed mines today this moring and would liek to share what i went throu,
i brough the ebay fog lights for 30 shipped on ebay, everything is good the only thing i had to do was cut out the hole for the fog lights,
next the plug that plugs into the fuse box under the streeing wheel, has room for 4 pins but if u look at the fuse box u only have 3, so i had to take the wire out of the whole it came in, which was all the way to the left if your looking behid the plug where the wire goes in the plug, to the far right, but before i did that i just wanted to make sure i was getting power their so i took a test light and checked
the wires where short on one end so i cut it and added more lenth to the wires b.c if i wanted to take my bumper off i wanted to know that it was going to yank on the plug
the last thing is the ghetto switch that comes with it, its too big cause its after market what i did was i filed the sides and the corners of the button that u presss on to turn on the fog lights, the front looks black but the sides looks white (after fileing it down), so i filed it down until the switch clicks on and off nicely and took a sharpie and colerd it black
the grounds i used where this, keep in mind that i have a k24 in my em2 not a single v
so the end results are this
any Q's i would be glad to help out
Old 04-02-2009
Re: ebay fog lights 30 shipped, correction
wow very nice look! how are they at night...
Old 04-02-2009
mdn217's Avatar
mdn217 is an unknown quantity at this point
nice post..im thinking about getting some fog lights. Are those ones any good or kinda cheap?? I might get an OEM kit...
Old 04-02-2009
tell me what you think, i took the pics on my iphone dont know why it came out white on my iphone but their yellow, i want them brighter, i'm going to get yellow hid's and put them in their when i have sometime, but for right now their great for 30 shipped!!! cant beat that, thanks god for china!! lol
Old 04-02-2009
their good for 30, cant beat that, but i'm thinkin of adding hid's to them
Old 04-02-2009
eyeheartvtec's Avatar
eyeheartvtec is on a distinguished road
theyre actually pretty nice lookin dude. i woulda figured ebay quality stuff wouldnt perform that well. sounds like a good buy to me!
Old 04-02-2009
kcari's Avatar
replace the fuse with a smaller usa made one.
Old 04-02-2009
sure will do, u think a 10a will do???
Old 04-02-2009
not bad. you may need to adjust the aim so they are lined up right and not aimed too high. i had real oem ones before and you could hardly see anything from the driver seat. fogs are mainly for looks tho not visibility. i would not recommend wasting money for hids in them, it looks like they already have lots of glare. which is good with the halogens now, makes your car more noticable.
Old 04-02-2009
kcari's Avatar
i think i replaced my 30 that melted with a 15.
Old 04-02-2009
yea i think their good, hey for 30, i cant go wrong their bright but i want them brighter,
Old 04-03-2009
well you can always try it out, hid kits are cheaper than $100 so you wont lose much if it looks bad.
Old 04-03-2009
Bone Stock!
dalaw's Avatar
where is your cruise switch?
Old 04-03-2009
either he doesnt have cruise, or he stuffed it behind the dash like me in ON pressed position.
Old 04-03-2009
manahoonie's Avatar
i'm a little into details... and i am going to guess that the kit came with screws to hold the fog light housing to the lower grille. BUT, it appears you took it upon yourself to use bolts?
the 'OEM' way of installying them is to have that tab w/ the screw holes to go on the 'outside' of that brace, instead of the inside like you have it...
otherwise, good install.
Old 04-03-2009
i took out it cuase i did the k swap and i'm going turbo so i need all the room i can get
Old 04-03-2009
yea it came with the screws and and tab but the tabs are so weak that when u put them on they bend right away so i used blots and nuts as u can see, i only used one tool the whole time and that was a kicthen nife, i can easly hide the bolts by spray painting them black, but i really dont care, its ok to me
Old 04-07-2009
hey guys i just wanted to let you guys know, on my way to new jersey, i stopped for gas and found that my fog lights have cracked , i'm so mad, dont know what to do, the ebay user is not registered, i'm so mad
Old 04-07-2009
it happens, they are made of glass and its a big area when rocks are flying at you. next pair you can try putting clear protective film but ive had bad luck with the vinyl burning if the car sits still and theres no wind to cool them.
Old 04-07-2009
i dont think it was the rocks i think it got so hot that when it rained the glass poped, so i think its that
Old 04-07-2009
ah yeah that would do it too. cheap glass (not pyrex) will do that. now you can always fix the ones you have, many people goto hardware store and get lexan pieces and cut out a lens from those. you can form them into a curved shape with a little heat. just break the rest of the glass out of your old fogs, then cut a new piece from lexan and glue it back in place. it should never break.
Old 04-07-2009
KTciv_03's Avatar
KTciv_03 can only hope to improve
^more trouble than its worth. just get another 40 dollar kit and slap them in there and sell what you dont need.
Old 04-07-2009
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
^then the same thing will happen..
Old 04-07-2009
lol yea thats true, well good news they guy replayed back and he said he sending me new ones, so i'm going find out want i can do so they dont break, the only thing i can think right now is to not turn them on when it rains, but i'll find something out, i may just replace the lens or something
Old 04-07-2009
wow thats pretty cool.
Old 04-07-2009
mdawg's Avatar
mdawg is on a distinguished road
Stupid question but I've only had my new civic for like 6 days, in the place where the fog lights are do you have to have a diff bumper or do the plastic pieces in mine just pop out for them?
Old 04-07-2009
lol read the theard
Old 04-07-2009
you gotta cut the bumper
Old 04-10-2009
mdawg's Avatar
Originally Posted by streetthrowback
lol read the theard
lmao how did I miss that
Old 04-12-2009
instead of starting a new thread....
this white clip does not fit securely onto the fuse box.. any ideas what to do?
Quick Reply: ebay fog lights 30 shipped, correction
