Components? what's the diff?
Old Mar 24, 2002
SpacemanBob's Avatar
SpacemanBob is an unknown quantity at this point
What's the difference between component speakers and just plain old speakers? And what exactly are crossovers, which seem to come with any set of component speakers i can find? thanks!
Old Mar 24, 2002
bake's Avatar
bake is an unknown quantity at this point
component speakers are just a name for a pair of midrange, tweeters, and crossovers, crossovers are designed to in a sense separate your music, tweeters get all higher pitch sound, midrange like the name says gets your mid pitch sound, and subs get the lower end sound, the crossovers will just let high notes come through and same down the line just like there shouldn't be awhole lot of words coming out of your subs, thats what the midrange is mostly for
Old Mar 24, 2002
thanks, so would you suggest getting component speakers, or just getting some good speakers and buying separate crossovers?
Old Mar 24, 2002
mohawkboom's Avatar
Definately components.. that way you can mount the tweeters higher up andlose most of your left channel high's because your knees are absorbing the sound [IMG]i/expressions/face-icon-small-smile.gif[/IMG].. better sound stage with components. better midbass.. better sound in general.
Cheers
Mohawk
Old Mar 24, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
cost more but well worth it. also different setup places. better imaging
Old Mar 24, 2002
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
Where can I get the stock Honda tweeter pods?
Also will they fit on a sedan?
Old Mar 24, 2002
What if the new HU i'm going to get comes with built in crossovers. Should I then just get normal speakers? thanks again!
Old Mar 25, 2002
KevinFWB's Avatar
KevinFWB is an unknown quantity at this point
Head units don't come with crossovers (at least in the sense your thinking) If a head unit had a built in crossover it would have many speaker outputs... Instead of 4, it would have 12 speaker outputs. Three for each "channel" 1 mid, 1 high, and 1 low for each of the 4 corners of your car. If you truely find a head unit like that, you probably can't afford it. I recommend the components, but it depends on what you want. If you just want in improved sound, you should be okay with the coaxials, but if your going for sq (sound quality) the compenents are the only way to go. Just buy the facotry tweeter pods and mount the tweeter in there. Its mainly preference, just keep in mind that there is ALWAYS something bigger and better, it just depends on how much you want to pay.
Old Mar 25, 2002
SuperSajin's Avatar
SuperSajin is an unknown quantity at this point
You can install regular 6 & 1/2'' in the door, but without the crossover the tweeters wont work, they'll be there for show.
Old Mar 25, 2002
Voiceofid's Avatar
End Bringer
yes, i also recommend a set of components. great clean crisp sound the cross over really does it's job, i can hear all the chirps and dings in the tweeter, and the air move in the 6.5
Old Mar 25, 2002
one last question....... So in the EX coupe that I have, you're telling me that I have crossovers already? Cause it's got 6 speakers........
Old Mar 26, 2002
SuperSajin's Avatar
yes, but if you go out and buy a componet set,the crossovers will come with it, i reccomend the infinity kappa set, they are $169.00 at www.ikesound.com, great buy.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ZoSoIV
Sep 17, 2015 07:17 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
