I AM AN IDIOT SO MOHAWK CAN YOU OR ANYONE ELSE HELP ME?? OR IS IT TOO LATE?
Old Mar 1, 2002
pimpdakota's Avatar
pimpdakota is an unknown quantity at this point
Ok i have a question about OHM's! if i bridge my power series 800 w 4 channel amp to 4 ohms then can it have my 3 1ow6's wired to a 6 ohm load? I'm looking at JL audios data sheets and rockfords sheets and they aren't helping me!
So should i run my 3 under powered 10 in a 6ohm conf. or run them in a 4 ohm conf.? or should i just toss 1 of my 10's?
i'm doing a custom install in my trunk! i have fiberglass laid and gonna put lid on tomorrow so i need serious help!
Also does pillow filling make a huge difference on sound quality? Much apreciated! dakota
Old Mar 1, 2002
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
first of all, we need to know if you have the 2, 4 or 8ohm subs.
Old Mar 1, 2002
Greg's Avatar
Greg is an unknown quantity at this point
He said he had 10W6's and all JL W6's are dual 6 ohm subs. I would run all 3 at 4 ohms
Old Mar 1, 2002
mohawkboom's Avatar
I'd say Run the 3 at 4ohm.. but your amps a 4 channel so that's not an option.... Sell the amp for a 2 Channel that's 4ohm Stable dude..... You AMp is brodgeable to 2x400Wrms at 4ohm..and you cannot run only 1 channel this will screw up the amp... As I said.. trade someone..or sell it and use the proceeds for a 4ohm Mono Stable 2 channel amp..
Cheers
Mohawk
Edit..it's late I start work in 6 hours.. PM me and I'll post a nice long winded descriptive post describing what Polyfill does..
Old Mar 1, 2002
pimpdakota's Avatar
so can i run the two w 6's at a 6ohm? like a 4x2 then seperate the two subs? question is? the three together right now with the amp i have they dont seem to hit very hard! so can i just use the two subs with the amp i have? 2 JL10w6's should move a lot of air huh? i think the three subs is too much! dakota
Old Mar 2, 2002
KevinFWB's Avatar
KevinFWB is an unknown quantity at this point
Simple solution... Buy a Class D Mono AMP. Check out the Directed 600D or the 1100D stable to one ohm and its a one channel amp. You wont have to worry about trying to bridge a two channel amp to three speakers etc.. Just run them parallel to the amp and run then voice coils in series if you need to. I wan't really paying much attention to the speakers that you are using, but it doesn't make sense to me to use different speakers at a different ohm load. Use a identical speakers and run the parallel them so that each speaker is getting the same amount of power and the same ohm load.
Old Mar 2, 2002
mohawkboom's Avatar
Dakota,
Sorry about that. I forgot your setup can be wired down to 1ohm as well. a good 600Wrms+ 1ohm mono stable amp would do your electrical system much better. Also W6's are not very loud subs to begin with. These are JL's old SQ subs..the W3's bump a fair bit harder.
Cheers
Mohawk
Old Mar 2, 2002
pimpdakota's Avatar
thanks guys !
solarpunk70
Apr 12, 2016 11:43 AM
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
MamaBear2015
Sep 15, 2015 09:35 PM
