Maybe Starting A Carputer Build
Canadian, Eh!
Rep Power: 252 Maybe Starting A Carputer Build
Where can I get the hardware to build it in Canada? I need a Canadian supplier for the intelligent DC-DC power supply and all the Mini-ITX goodies. Preferably in Alberta.
Electric Boogaloo...
Rep Power: 303 They'll ship there I'm sure. Or find a member here to buy them for you and ship them to you, if they try to rape you on shipping. Shipping isn't that much to Canada. I sent a T2001 Roof wing to someone on here and it was like 13 bucks. It was an odd shape and fairly heavy. I'm sure those goodies wouldn't weigh near that, and they would fit in a small sized box.
PWIT
Rep Power: 276 i wanna build one too, but im not sure exactly what i need, im going to use a lappy though cause well i have an extra one...
Canadian, Eh!
Rep Power: 252 I'd advise against a laptop for many reasons.
The reason I want something in Canada is so I don't have to pay customs fees when getting it across the border. I paid $50 for my stereo on top of shipping, just for duties. And they're already charging me $25 US for shipping as it is. They are raping me.
Canadian, Eh!
Rep Power: 252 I think the most important part of a carputer build is the power supply. And for this reason, companies make auto specific power supplies for computers because of the voltage levels. Cranking your car with a computer hooked to it is going to pull a conventional 110 volt PSU to its limits and eventually will kill your laptop. Same as using desktop parts. The auto PSU provide a constant 12 volt current so there are no high or low spikes during cranking and it won't harm your machine. They also have startup/shutdown controllers so they turn on and off with your ignition which saves you a headache!
You can get them at www.mp3car.com, unfortunately they're about $100 + shipping. And that's USD. And since they don't come any higher than about 160 watts, you can only use them to power laptop parts so a desktop build won't work with them. I've found out this much in 3 days of research and I'm still learning.
Yes, it's an Acura EL
Rep Power: 344 Hi DeX, when it comes to DC-DC power supplies pretty much the only place to get the kind you need (ignition power off etc) is mp3car.com, as I explained during our brief pm exchange. Everyone I know personally with a carputer in Canada has had to get something shipped across the border at some point. Everything else such as mobo/cpu/etc you can buy at local computer shops. ITX is hard to find around here so if you're going that route you're either special-ordering from a local shop or going to mp3car...either way major moola. I didn't want to get a case from mp3car so I just bought a microATX mobo and case and then chopped pretty much 3/4 of the case off. My biggest problem now is that the Opus 150 is starving the mobo due to the P4 I've got in there, I got a little greedy. Still works though, and I'm thinking of adding another Opus or maybe just a regulator to help with the load. Trust me the shipping costs are murder and UPS is a ripoff with their freaking brokerage fees, but if you've done your research you can maximize your order by getting everything you need from the states all in one shot. When it comes to modding you've got to pay to play and it's even worse in Canada. But once you get it all working trust me you won't care how much it cost. In fact I've already started planning my second carputer setup, and a good number of the parts will be coming from mp3car.com.
Originally Posted by CenZ
why you advise with no going with a laptop.
A relay off the run terminal of the ignition will work.
(neighbor is running a mini-mac in his RSX)
OptimisticWay
27
07-06-2015 12:56 PM
Touge
Ottawa
05-23-2015 05:39 AM
Touge
05-23-2015 05:39 AM
Touge
05-20-2015 10:53 PM
black2k1vtec
12-06-2001 09:49 PM
